What is this?
Randy Mock
Topic author - Posts: 54
- First Name: Randy
- Last Name: Mock
What is this?
I made a purchase today.
Some are T some not so much.
Any help is appreciated.
Probably for sale soon.
Re: What is this?
That's a Babbitt setting hammer underneath the gray gizmo - the white tubes appear to have Babbitt cutting tooling !
Randy Mock
- First Name: Randy
- Last Name: Mock
Re: What is this?
I will get everything out for a better picture tomorrow.
- Last Name: Tannehill
Re: What is this?
Randy Mock
- First Name: Randy
- Last Name: Mock
Re: What is this?
I’m hoping the gray gizmo is something rare.
It’s likely the profit off this job.
Chris Paulsen
- First Name: Chris
- Last Name: Paulsen
- * REQUIRED* Type and Year of Model Ts owned: 1910 Touring, 1914 Pickup
Re: What is this?
The gray “gizmo” is the feed for line boring equipment. Not necessarily rare or valuable but a good item if it’s not worn out. I’d be interested if it’s available and in good condition.
Re: What is this?
Those axles look like you might have a "wide track" model T. Quite rare.
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Re: What is this?
The grey gismo is the Feed mechanism for an Aamco Line boring bar. Given the other items in that box, you might have the other parts that go to it as well. Post more pics of your treasures.
The ribbed tool laying under the gear rack of the feed box is a KRW main bearing babbitt peening tool.
Randy Mock
- First Name: Randy
- Last Name: Mock
Randy Mock
- First Name: Randy
- Last Name: Mock
Re: What is this?
I assume all babbitt related
Re: What is this?
W.A.G. - appear to be Model A related. There's a pouring jig, pouring blocks and a thrust cutter.
Dave Sullivan
- Last Name: Sullivan
- * REQUIRED* Type and Year of Model Ts owned: 1923
Re: What is this?
I'd say the (Grey gizmo) is part of a line bore outfit.. Dave in Bellingham, WA
dobro1956
- First Name: Donnie
- Last Name: Brown
Re: What is this?
#2 is a rear main thrust facer. The size of shaft will determine if it is A or T. #5 are main bearing pouring blocks. A set of them is usually 6 blocks but 2 long ones and 1short one will do.
Randy Mock
- First Name: Randy
- Last Name: Mock
Re: What is this?
Thanks for the info
