Horn Switch Reproduction for '26?
Topic author - Posts: 1002
- Last Name: Bartsch
Is anyone making repro horn switches for the '26-'27 T's? A cursory search turned up only the steel switch mount shell and the phenolic switch button, but not the 'guts', so I thought I'd ask here before I search further. (I'm seeking the two-wire column mounted electrical contact unit that energizes the 6V battery horn on my '26 coupe.) Thanks, jb
Re: Horn Switch Reproduction for '26?
Lang's carry/carried a nice horn button assembly - https://www.modeltford.com/item/8028X.aspx
Then you'd need to order the correct button for your year.
Thanks, Steve, I totally misread that when I searched. I have a NOS mounting bracket and button. Best, jb
