Transmission Brake Band Spring Tool
Bill Everett
First Name: Bill
Last Name: Everett
Board Member Since: 2011
Post by Bill Everett » Tue Nov 22, 2022 4:15 pm
How does this tool mount so that I can take off the brake pedal without tension from the spring pushing the nut and/or washer out, and into the transmission?
Any help would be appreciated.
Thank you.
RGould1910
Last Name: Gould
Re: Transmission Brake Band Spring Tool
Post by RGould1910 » Tue Nov 22, 2022 5:12 pm
I bring the ears together so I can unscrew the nut and remove the nut and washer from the pedal shaft. I hold it at a 45 degree angle so each prong sits just under the rearward lip of the band. To be a safe I stuff the surrounding open areas with crumpled paper towels so things don't fall down in the pan.
Bill Everett
First Name: Bill
Last Name: Everett
Post by Bill Everett » Tue Nov 22, 2022 7:19 pm
Thank you, Richard.
Post by Steve Jelf » Tue Nov 22, 2022 10:20 pm
When you stuff rags in the transmission to catch things that might be dropped, count them going in and coming out. :)
