I'm trying to identify the proper name for the square U-bracket that holds the rear spring to the rear of the frame. There are 2 per car.
If anyone has one for sale I need one. (part found)
Thanks everyone for the information
Trying to identify a part name
Topic author - Posts: 29
- First Name: Kristian
- Last Name: Thurber
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Re: Trying to identify a part name
According to the Ford Price List Of Parts, they are called "Rear Spring Clip".
Thank you, found a set on ebay!
- First Name: Warwick
- Last Name: Landy
- * REQUIRED* Type and Year of Model Ts owned: 1916 RHD Canadian Touring 1916 Pickup 1926 Fordor 1925 Dalgety Tourer 1916 Speedster
Jeff, you are correct. Parts book describes part number 3833 as "Spring Clip". I have always called them rear "U Bolts". I thought the piece that hangs over the spring to keep the leaves aligned would be more appropriately called the "Spring Clip" . That one, part 3848 is actually called "Rear Spring Retainer Clip and Rivet". As they say, you learn something every day!
I could sell you 1
