Starter Woes !
Starter Woes !
Post by RajoRacer » Wed Dec 21, 2022 8:22 pm
Helping a buddy out with some "starting" problems - this is what you DON'T want to find ! I thought Ron P. (starter builder retired) & Jeff S. will know the cause of this - now I gotta dig through the shelf ! Hold the damn battery cable tight when tightening it on the stud !!!
Re: Starter Woes !
Post by Norman Kling » Wed Dec 21, 2022 8:37 pm
A few years ago I bought a kit from Ron Patterson which had the large copper strip. Then I went to visit Tony Bowker who has a very heavy duty soldering iron and we soldered it into place. It has worked very well ever since. To help prevent this from happening, you need to be sure the nut toward the insulator next to the starter housing is tight and that the threads are good so that when you tighten things up it will not turn the post.
Last Name: Kuehn
Re: Starter Woes !
Post by John kuehn » Wed Dec 21, 2022 8:57 pm
More than a few T starters have been over tightened to the point of breaking the stud from the winding! Nothing new when not thinking of what your doing. I learned the hard way years ago.
Last Name: Tannehill
Re: Starter Woes !
Post by JTT3 » Wed Dec 21, 2022 9:21 pm
Craig Leach
First Name: craig
Last Name: leach
Re: Starter Woes !
Post by Craig Leach » Wed Dec 21, 2022 10:43 pm
Wasn't some starters riveted to prevent that? Seems every $5 -$10 starter I pick up is that way, and has a bent shaft.
Craig.
Re: Starter Woes !
Post by Allan » Thu Dec 22, 2022 12:20 am
The threaded post is riveted and soldered. The best solution is to grind down a thin wrench to fit the nut on the insulat0r, hold that on that nut while you do up the top nut. That will stop the assembly trying to rotate. Same goes for the terminals on original starters switches.
Hope this helps.
Last Name: Juhl
Re: Starter Woes !
Post by Oldav8tor » Thu Dec 22, 2022 8:15 am
I recall that Ron Paterson told me that a clue that the stud was loosened was if it got hot to the touch after cranking the starter. It's the first thing I check if someone has a balky starter.
Re: Starter Woes !
Post by DanTreace » Thu Dec 22, 2022 8:44 am
Hope this helps.
Allan, that is the best advice! And use same method on the generator terminal too. Posted this pic I made on earlier threads of same issue.
Re: Starter Woes !
Post by Jerry VanOoteghem » Thu Dec 22, 2022 9:44 am
No matter how you tighten the nut, keep your eye on the stud while tightening and notice if it's beginning to turn. Put a dot on it with a magic marker if you need to.
Re: Starter Woes !
Post by Allan » Fri Dec 23, 2022 2:27 am
There is enough thread length in the stud to allow 3 nuts to be used when fitting up. Put one on and run it down, without screwing it so tight it will want to rotate the stud. Then fit two more, and lock them to one another by jamming them together. You can hold this locked pair on the lower nut, and then do up the bottom nut on the insulator, without the threat of the stud turning. Then unlock the top two.
Hope this helps.
John.Zibell
Last Name: Zibell
Re: Starter Woes !
Post by John.Zibell » Fri Dec 23, 2022 8:58 am
Not being a fan of the extra nuts, I used a dremel with a cutting wheel to place a slot in the top of the stud. I then use a screw driver to hold the stud when I snug down the nut.
1926 Tudor
Ron Patterson
Re: Starter Woes !
Post by Ron Patterson » Sat Dec 24, 2022 9:54 am
I prepared an article about this common Model T starting motor problem.
Repairing a Common Model T Starter Problem.pdf
(958.95 KiB) Downloaded 130 times
Ron Patterson
Re: Starter Woes !
Post by RajoRacer » Sat Dec 24, 2022 10:41 am
Fabulous tutorial Ron - many thanks !
