Stainless tie wire
Topic author - Posts: 250
- First Name: Dennis
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Stainless tie wire
What gauge is the stainless steel tie wire used on engine and transmission bolts? I know it must be dead soft for twisting and bending but i am wondering on the gauge or diameter.
- First Name: Les
- Last Name: Schubert
Re: Stainless tie wire
I don’t use Stainless Steel wire. Just ordinary steel wire.
- Last Name: Humble
I use .032 for smaller bolts, and .041 for larger.
- Last Name: Juhl
Same as Jeff - I also have a pair of aircraft safety wire twist pliers. If you're not likely to use them a lot, Harbor Freight makes a cheap pair for $10.
