I am in the process of making a couple new clutch drums. The only dimension I am missing is from the face the washers right against to the set screw hole. Obviously that is critical. I know there were two different numbers for early cars and late cars. At least that is what I understand. Does anybody have that dimension or a drawing?
Thank you in advance.
New clutch drum
greenacres36
Topic author - Posts: 164
- First Name: Brian
- Last Name: Williams
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Re: New clutch drum
No dims, but__________https://www.mtfca.com/phpBB3/viewtopic.php?f=2& ... +b#p218965
Joe Bell
- First Name: Joe
- Last Name: Bell
Re: New clutch drum
Brian I have boxes of them, you are welcome to what you need, I am in Tiffin Ohio!
greenacres36
- First Name: Brian
Re: New clutch drum
I sent a pm to you Joe
