FS 09/10 steering column (disassembled) column housing, shaft, lower frame mtg bracket, pitman arm, planetary gearbox, and brass quadrant.
OEM Housing rough but easily restored. OEM Frame bracket x-cond. with new bushings. Pitman arm is custom fabricated, dimensionally correct. OEM Planetary gearbox x-cond. OEM Quadrant very clean with light tooth wear. OEM Shaft is correct 4:1 with ligjt surface rust, installation ready.
Will not separate parts 1250.00
513 three seven eight 4235.
FS 09 10 steering column
Scott Rosenthal
Topic author - Posts: 395
- Last Name: Rosenthal
Scott Rosenthal
Re: FS 09 10 steering column
Plus Shipping.
