Question about older replacement coil capacitors…
Chris Bamford
First Name: Chris
Last Name: Bamford
* REQUIRED* Type and Year of Model Ts owned: 1924 Speedster 1926 Touring
Post by Chris Bamford » Mon Jan 16, 2023 3:08 pm
The four smaller capacitors were purchased locally 25 years ago but originated from Macs. The larger one is current stock from Langs.
I’m assuming the Langs caps are good to use — is there any concern about the older, smaller ones or should they function and last equally well?
Re: Question about older replacement coil capacitors…
Post by Scott_Conger » Mon Jan 16, 2023 5:01 pm
Chris
being that old there is an almost certainty that they are not the correct value. Lots of study and collaboration with a manufacturer went into getting the correct item which you got from Langs. For the aggravation those MAC's caps will likely bring once buried in tar, I personally would pitch them and count myself as being ahead of the game.
Chris Bamford
First Name: Chris
Last Name: Bamford
Post by Chris Bamford » Mon Jan 16, 2023 8:42 pm
Thank you Scott
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Mon Jan 16, 2023 10:42 pm
I have occasionally recommended buying a capacity testing meter. They are readily available and quite affordable. The Ignition coil capacitors should be checked annually to determine if it is time for a rebuild.
Art Mirtes
Last Name: Hatch
Post by Dan Hatch » Tue Jan 17, 2023 2:51 am
Chris: I think if you will do a search about capacitors on this forum you will find many threads from years go about the right one to use. Most likely the smaller ones are the wrong construction. As in the wrong type. Many years ago this subject was as popular as water pumps and types of oil.
If these are wrong type, I can not tell from your picture. They will work for a while, but can fail at any time. Dan
Harry Lillo
First Name: Harry
Last Name: Lillo
Post by Harry Lillo » Tue Jan 17, 2023 11:39 am
Our current Foothills Model T newsletter has an article
written by our own Canadian Coil King, Peter Anderson,
about coil capacitors. It is amazing what he has found for
capacitors in his years of coil rebuilding.
https://static1.squarespace.com/static/ ... anuary.pdf
Your capacitors appear to be similar to the ones in the second picture.
Peter explains that these failed when he poured the hot replacement tar
back into the coil box.
Harry Lillo Calgary
Post by TXGOAT2 » Tue Jan 17, 2023 11:59 am
I would not use any old stock capacitor unless fresh ones were not available. Capacitors age, whether they are used or not. Old ones are not worth taking a chance on. I would also want to be certain that what I installed was the correct type of capacitor for that application.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Jan 17, 2023 1:35 pm
Interesting topic.
1. I don’t retar when I replace the condenser
2. I have had great success using automotive ignition condensers
45 years and going!
Post by TXGOAT2 » Tue Jan 17, 2023 2:25 pm
How do your points hold up?
Do you use a condenser for 6 volt systems or 12 volt systems?
JohnH
Last Name: Hunter
Board Member Since: 2002
Post by JohnH » Tue Jan 17, 2023 3:46 pm
Those older capacitors in the photo are .047uF. That is way too low of a capacitance value. It should be about ten times that; i.e., .47uF.
Aside from that, the dv/dt rating is most important. This is the rating of how quickly the voltage across the capacitor can rise in a given amount of time without destroying it. The dv/dt rating needs to be at least 600V per microsecond. This is not the same as the ordinary DC working voltage.
The DC working voltage needs to be at least 400V.
The Sprague Orange drop capacitors which were being sold around 20 years were suitable, as was a smaller capacitor which later came from Fun Projects, which had a dv/dt rating of 1500V/us.
This is an early catalog listing when FP was still selling the Sprague capacitors:
See this data for the Sprague capacitor - the appropriate type is 418P47494M.
capacitor418P.PDF
(110.68 KiB) Downloaded 67 times
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Jan 17, 2023 4:18 pm
The car is 6 volt but I run it on magneto. I often hand crank start on mag (the car is a 27 roadster). Many thousands of miles on them.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Jan 17, 2023 4:21 pm
The car is 6 volt but I run it on magneto. I often hand crank start on mag (the car is a 27 roadster). Many thousands of miles on them. Haven’t changed the points since I installed the condensers. Just had them “retuned” on latest equipment!!
