1926 Brake drum Bushing
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Sun Jan 22, 2023 4:38 pm
Iam trying to confirm that the 26-brake drum had only one bushing and not two.
I remember reading it somewhere before but can't find it again and all the diagram pictures I find have the early brake drums.
any guidance is appreciated.
Bryant
Re: 1926 Brake drum Bushing
Post by Scott_Conger » Sun Jan 22, 2023 5:38 pm
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Sun Jan 22, 2023 6:23 pm
Thanks Scott, that’s the proof I need. I always seem to forget about the encyclopedia.
Bryant
Post by RajoRacer » Sun Jan 22, 2023 8:25 pm
There is another extensive article in the Service Bulletins stating how to "index" the driving plate to the brake drum when reaming and a special double reamer that was put out by Ford.
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Sun Jan 22, 2023 9:52 pm
Thanks I will check that out.
I’ve been a fan of the Model T tips videos
They have some good videos on the alignment processes.
Bryant
Post by Mark Gregush » Sun Jan 22, 2023 9:55 pm
While the drum may have only had 1 from the factory, 2 will give better support.
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Sun Jan 22, 2023 11:15 pm
I was pondering that myself. I wonder the reason for them removing it.
Bryant
Last Name: Tannehill
Post by JTT3 » Mon Jan 23, 2023 12:20 am
Saving time & money! I do use 2 in any rebuild. Just asking where exactly would you locate the one bushing? I guess at the top of the brake drum shaft close to the clutch basket?
Kerry
Last Name: van Ekeren
Post by Kerry » Mon Jan 23, 2023 2:21 am
No, at the fly wheel end, the drive plate bush carries the other end.
Last Name: Hatch
Post by Dan Hatch » Mon Jan 23, 2023 5:21 am
The Service Bulletin about this explains the why.
Glen McConachie
First Name: Glen
Last Name: McConachie
* REQUIRED* Type and Year of Model Ts owned: A few 1926 - 27 Tudors and coupes
Post by Glen McConachie » Mon Jan 23, 2023 5:46 am
Has anyone come up with a reproduction of the reamer?
Would be quite helpful for setting the drum and drive plate up so everything runs true
Cheers
Glen
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Mon Jan 23, 2023 8:24 am
The best way to explain is to watch the model t tips videos on brake drum and drive plate alignment. No reamer necessary. Apparently they had reamed in the past but have built many transmissions and refined the processes to boring and finishing with Timesaver. Good videos. Someone here might know how to post the link.
Bryant
Post by speedytinc » Mon Jan 23, 2023 8:34 am
Bryant
To save a penny or 2 on each unit.
I have seen quite a few with only one bushing. The smaller drive plate bushing takes all that rear load. They are usually very/excessively worn. I ALWAYS put in that second bushing. I see no advantage to leaving it out. I dont ream the bushings, I bore them for precise alignment & fit. Everything fits properly with no misalignment bind.
Post by Scott_Conger » Mon Jan 23, 2023 9:50 am
John
I, too, have bored and fit them. But really, 3 bushings spread across 2 semi-precise parts creating a 3-bushing assembly is not a really great design. I don't think they saved 2 cents on a bushing, I think they saved 50 cents in farting around and making sure the 3 were all in a line. I don't know your exact method, but mine takes time, time, time.
Since it took so long for them to adopt this change, I would not be surprised if this was not something in common practice in repair shops which gravitated back to the factory.
Post by Original Smith » Mon Jan 23, 2023 10:27 am
You have a bushing in the driving plate, so you don't really need the extra bushing in the brake drum.
Post by speedytinc » Mon Jan 23, 2023 11:29 am
John
Scott, I use a long boring bar on a lathe. All the drive plate mating surfaces get a clean up cut. Drums typically have some warp & run out.
The drive plate bushing is also bored & mating surfaces cleaned with a minimum cut. As a check, the drum goes on the transmission center shaft with the output plate bolted together. There is no extra rotational friction. That confirms the 3 bushings are all aligned. The procedure doesnt seem to take any extra time since I not using reamers & its optimal for bushing fit & finish. I doubt this operation could create close enough alignment to not have added rotational friction or lock up with reamers following the slightly off center nature of bushings. Yes, you have to be right on to get 3 bushings in 2 different mating parts to align. I rather prefer the extra support of the 3rd bushing.
I would think Ford had their machine processes down where everything assembled reasonably close. There may have been less than perfect alignment, but it would have been "good enough" for a model T. Run in would have "fixed" things.
