Front Cover Mag Drive
got10carz
Last Name: Meixner
* REQUIRED* Type and Year of Model Ts owned: 1911,13,14,19,23,25,26,27
Post by got10carz » Mon Jan 23, 2023 3:53 pm
Please look at pictures and comment on the oil tube that goes between the fill area and end of the drive. I'm thinking there would be very little oil mist that high to feed the drive. Would a drip oiler be better or maybe just grease. The tube is basically horizontal. Anyone running one for a long time? I also intend to leave the cam seal out, thoughts on that also.
Re: Front Cover Mag Drive
Post by speedytinc » Mon Jan 23, 2023 4:19 pm
Cam seal goes in a stock cover. This takes the cover's place - no cam seal.
I have one of these units on a stationary motor.
Leave the oil line on. Mist will provide the very little needed to lube the bushing.
got10carz
Last Name: Meixner
Post by got10carz » Mon Jan 23, 2023 4:33 pm
I feel foolish mentioning the seal. Correct the seal is in the cover.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Mon Jan 23, 2023 4:56 pm
That oil tube connects the small oil reservoir in the filler neck to the shaft bushing. The reservoir will hold oil for quite a while, If the shaft and bushing are in good shape. I think I still have the drawings to make a new shaft and bushing…
BUSHMIKE
Last Name: Cushway
* REQUIRED* Type and Year of Model Ts owned: 1925 TT, 1926 TT, 1926 TT
Post by BUSHMIKE » Mon Jan 23, 2023 5:26 pm
It looks like it would be fairly simple to extend the horizontal tube into the oil fill area and then solder a 90 onto it. You could fill the line with an oil can any time you wanted.
Post by speedytinc » Mon Jan 23, 2023 5:34 pm
Yes, i had forgotten. Inside the filler is a damed area that holds oil. The tube runs into it to feed oil to the bushing from that reservoir. I believe in practice this reservoir is automatically kept filled enough from the collected oil vapor. Its a self lubricating system.
BUSHMIKE
Last Name: Cushway
Post by BUSHMIKE » Mon Jan 23, 2023 6:03 pm
The damn & trough design was very prevalent in engines and transmissions of many 20’s-50’s tractors. It was obviously very effective. I once watched a video of the oil mist inside a running Model A engine. It was a dense fog.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Mon Jan 23, 2023 7:41 pm
Not sure how much oil vapor would condense in the reservoir or splash up from the timing gears… but you can’t avoid getting some in there while topping off. I never saw mine empty after a drive. Wanna say there was a wick at the bushing end
When installing, watch the drive gear clearance. I had a few trimmed pan gaskets under the front plate to set the gear mesh
