Regan wheel press
pgbaresel
First Name: Paul
Last Name: Baresel
* REQUIRED* Type and Year of Model Ts owned: 1924 touring and a 1921 depot hack
Regan wheel press
Post by pgbaresel » Thu Oct 08, 2020 10:04 am
Does any one have construction plans for a Regan wheel (spoke) press? I would like to build one. Thanks
Re: Regan wheel press
Post by Steve Jelf » Thu Oct 08, 2020 10:21 am
MCobb
First Name: Martin
Last Name: Cobb
* REQUIRED* Type and Year of Model Ts owned: 1917 engine only
Post by MCobb » Mon Jan 23, 2023 4:24 pm
I would like to build a press with these plans but they are not quite clear enough for me to read them, even when I enlarged them. Can anyone post clearer drawings?
MCobb
First Name: Martin
Last Name: Cobb
Post by MCobb » Mon Jan 23, 2023 4:29 pm
Thank you! these are very clear.
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Mon Jan 23, 2023 5:16 pm
i had a similar issue with not being able to see some things like these plans well enough to read them. I went by the local christian ministry that sells donated items to help the poor and bought a 42 inch plasma monitor for 20 bucks. Been using it now for about 3 years. I can SEE stuff now! :D
Emeraude
Last Name: Loranger
* REQUIRED* Type and Year of Model Ts owned: 1921 touring
Post by Emeraude » Tue Jan 24, 2023 9:40 am
I have used this press on 2 cars and it has 2 issues. The height of the 4-4 s are only high enough for the rear wheel and for the front I had to add 2-4s to get enough height. Other wise worked ok
