What are these holes in the firewall for?
RonGlowczewski
Post by RonGlowczewski » Sat Jan 28, 2023 2:48 pm
The firewall that came with my stripped chassis is a reproduction and I am looking to buy an original firewall. I have no idea what these 2 holes are for on the passenger side. Can anyone tell me? 1925 Roadster.
23ford
First Name: Warren
Last Name: Webb
Re: What are these holes in the firewall for?
Post by 23ford » Sat Jan 28, 2023 3:10 pm
choke rod adjustment for carb
Post by speedytinc » Sat Jan 28, 2023 3:33 pm
The 25's used the same choke/mixture single control rod as the improved T's. Before this the choke rod was much further up on the F/W attached to a riveted on bell crank. So, I can confirm what it is not, but not what it is. This looks like a job for Original Smith.
Post by Rich Eagle » Sat Jan 28, 2023 4:11 pm
Some of the photos here might help.
https://www.mtfca.com/discus/messages/7 ... 1506901129
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Sat Jan 28, 2023 4:17 pm
Might vary by year, not Ford supplied holes as far as I know.
Last Name: Hatch
Post by Dan Hatch » Sat Jan 28, 2023 4:20 pm
Late 25 or 26/27 TT.
Post by speedytinc » Sat Jan 28, 2023 4:28 pm
Rich posted pictures that are instructive. I cant tell for sure, but, that hole could be for the single mixture/choke rod.
The firewall has the earlier separate choke bell crank & mixture holes also. Transition?
Humble J's looks to be a 24, early 25? style F/W with the separate controls.
Last Name: Juhl
Post by Oldav8tor » Sat Jan 28, 2023 6:08 pm
might someone have routed a speedometer cable thru one?
su8pack1
Last Name: Kelly
* REQUIRED* Type and Year of Model Ts owned: 1925 Roadster
Post by su8pack1 » Sat Jan 28, 2023 8:45 pm
This is my 1925 roadster I picked up last fall. Engine # puts it the first few days of May 1925. From what I've read the late 25 to 26/27 used the choke rod without the bell crank similar to the later Model A setup. On mine I think someone tried to convert it to the newer setup as the bottom hole was enlarged and the choke rod has a section welded on and the end squared up to fit the u-joint setup (choke rod sleeve and wire were missing). I'm in the process of putting it back to the bell crank style. Just waiting on some parts now.
RonGlowczewski
Post by RonGlowczewski » Sun Jan 29, 2023 12:15 am
Thanks for the information!
Last Name: Humble
Post by Humblej » Tue Feb 07, 2023 9:29 pm
Update, and more mystery. I checked my unrestored 1924 roadster firewall and it has those 2 holes with nothing going thru them. My choke and mixture go thru other holes in the firewall and spedo cable goes thru the floorboard. The floorboard has a relief area to clear the holes.
Post by Original Smith » Wed Feb 08, 2023 10:34 am
The rust makes it difficult to identify. Does that firewall have four holes for the patent plate or two? Two is a 1925. Late 1925 firewalls have no bell crank for the carburetor, but the two holes for it are still there.
