10 tooth pinion question
Dennis Prince
Topic author - Posts: 404
- First Name: Dennis
- Last Name: Prince
I have a 10 tooth pinion that is marked 10-42, will that work on a 40 tooth ring gear? It looks just slightly different. Thanks for any help that I can get. Dennis
Art M
- First Name: Art
- Last Name: Mirtes
Re: 10 tooth pinion question
It will probably work but would be noisy.
Art Mirtes
Art Mirtes
Was the new pinion designed to run with Ford gears? NO
Will it? Maybe.
Will it create new fit issues with gear teeth clearance? Likely.
Will it be noisey? Maybe.
Is the metallurgy good to where a tooth wont break off? Maybe.
Back in the day, changing to a 10T pinion meant only pulling the D.S. Doing that with this gear would certainly be a problem.
You can roll the pinion on the intended ring gear. If it seems to mesh without clicking, it might work.
All the risk, hassle & potential wasted time worth it?
NO, not when a NOS ford gear is readily available here @ a fair price. NOS!!!
(I bumped it up just for you)
Will it? Maybe.
Dennis Prince
- Last Name: Prince
Thank you John, I called and am getting the one that you pointed out. Thanks again. Dennis
Wise decision. & you cant go wrong with genuine NOS.
Mark Chaffin
- Last Name: Chaffin
No one makes a "new" 42 tooth ring gear. Good luck finding a good used one.
