Fully rebuilt Moore auxillary transmission FS
				m2m
- First Name: Constantine
- Last Name: Mandylas
For Info on Moore transmissions see the link below (but note that the shifter on mine is of a different design):
http://www.mtfca.com/discus/messages/118802/139700.html
Moore was possibly the 3rd most popular aux. trans after Ruckstell and Warford. Advantage over Ruckstell is that the Moore has a neutral (so you can have the T towed a long distance without fear) plus if you have an early rear end you don't lose that look. The Moore is rear mounted so no heavy weight hanging off the back of your engine/transmission like the Warford. And rear mounted means better weight distribution for speedsters.
I'm putting up for sale my never used (rebuilt about 5 years ago) Moore underdrive that comes complete with a shortened tube and a newly made shortened driveshaft. It was rebuilt my someone well known in antique Ford circles for his quality work. The gears are good and new parts were machined as part of the rebuild.
Price is $2000 and I have more in it than that. It's located in NW AR but I'm likely doing some travel soon and might be able to delivered it closer to you. It's too big and heavy to ship.
				m2m
Re: Fully rebuilt Moore auxillary transmission FS
I will take some photos in the next day or two.
				m2m
I can email more photos to anyone interested.
				1913Runabout
- First Name: Brian
- Last Name: Harlamoff
- * REQUIRED* Type and Year of Model Ts owned: 1913 Runabout, 1922 speedster
Is that a stock Ford spool and Hyatte roller bearing?
Do you have the rest of the shift lever?
Brian
Santa Cruz CA
Brian
Santa Cruz CA
The Moore transmission does use a standard spool and Hyatt bearing at the rear.
All that appears missing from the shifter is short length of water pipe. Mine is about 15" long, threaded on the end to take a screwing knob.
				Art M
- First Name: Art
- Last Name: Mirtes
What is the gear ratio. And is it underdrive and direct only and no overdrive. Just curious
				m2m
As Allan mentioned, this version of the Moore didn't have a special shifter (unlike the one in the link at the top). A pipe or rod (cut to your desired length) with a knob on the top as all you need. You should easily be able to find something that works, maybe something similar to this:1913Runabout wrote: ↑Mon Oct 31, 2022 6:01 pmIs that a stock Ford spool and Hyatte roller bearing?
Brian
Santa Cruz CA
https://www.summitracing.com/parts/upd- ... UYQAvD_BwE
Art M, The Moore was a sliding-dog shift with direct and 50 percent underdrive. In good condition, they are easy to shift, and although they do have a neutral, rarely miss or get stuck in neutral. However, it is possible to get stuck there, especially if one kills the engine mid-shift? And therefore good brakes of some sort not relying on the driveline are a necessity. Same with a Ruckstell.
I wish I could afford this. They were one of the earliest auxiliary transmissions for a model T. And allow a good mountain intermediate gear for brass era model Ts.
Tim Rogers
- Last Name: Rogers
- Board Member Since: 2013
Wasn't aware that Ruckstell made an auxiliary transmission, just the 2-speed axle- learn something new every day.
Anyone have a picture of one?
- Last Name: Hatch
Email sent. Thanks Dan
				m2m
Still available.  Please note that the transmission is now in storage in Kansas (I moved it from Arkansas).
				m2m
Still available.  I've had some interest but distance from potential buyers seems to be the problem as it's not something that can be shipped easily.  There's a chance I might be able to get it to Chickasha Pre-War Swap Meet.
				m2m
Still available.
				Poppie
- First Name: Neil
- Last Name: Martin
- * REQUIRED* Type and Year of Model Ts owned: 11 tourer 18 tourer 18 TT
Good one Tim.....n
				moddamatt
- First Name: Matthew
- Last Name: Lewis
Hello, do you happen to have any measurements or detailed drawings/pictures of the rear section? I know it uses stock model t parts but I need a better look at the rear plate that bolts to the T rear end.
