Reproduction Horn from Texas T
Topic author - Posts: 322
- First Name: Ronald
- Last Name: Bakow
- * REQUIRED* Type and Year of Model Ts owned: 1915 Model T Touring
I think I am going to need a horn on the 24 Coupe that I will be getting soon as all photos indicate that the horn is MIA. That said I came across a reproduction horn from Texas T that looks like it might do the trick. Has anyone purchased this re-pop? Is it any good? Appreciate your feedback as they are proud of it at $234.95.
- Attachments
- T6432E Horn.jpg (34.55 KiB) Viewed 1557 times
Re: Reproduction Horn from Texas T
It looks very similar to the original horn. I think you should be able to find one which will work at a swap meet. It will cost much less and usually with a little adjustment can be made to sound very good.
I believe Fun Projects was the repro manufacturer of the horns - no longer in business but his items were top notch reproductions !
- First Name: Matthew
- Last Name: Sinclair
- * REQUIRED* Type and Year of Model Ts owned: 1921 Coupe
What happened to fun projects?
Sold out to Birdhaven a number of years ago.
- First Name: Morgan
- Last Name: Blanchard
I called Texas T parts last month trying to buy one of their battery horns. They didn’t have any in stock and were kind of odd about it. I called them in December to buy an Akurate oil gauge and they were out of that as well, and had the same odd attitude. Almost like I was bugging them asking about it.
I ended up buying a horn off of the wire.
I've not had a problem finding originals. Why bother with a repro?
