SOLD: K R Wilson Model T Pan Straightening Jig
Topic author - Posts: 131
- First Name: Eric "Gator" & Paula
- Last Name: Gould
- * REQUIRED* Type and Year of Model Ts owned: 1915 Southern Wide Track Touring, 1918 Couplet, 1919 Canopy Express,1920 Center Door Sedan
- Board Member Since: 2003
SOLD: KR Wilson Model T Pan Straightening Jig. Very good shape, has not been used as an anvil. $1,000
- Last Name: Tannehill
Re: For Sale: K R Wilson Model T Pan Straightening Jig
Gator I want it, I’ll give you a call in the morning on the pan Jig.
- First Name: Darryl
- Last Name: Bobzin
- * REQUIRED* Type and Year of Model Ts owned: 2, '25 T Runabouts, '14 Touring
John, You are about to gain many new friends with your purchase.
Re: SOLD: K R Wilson Model T Pan Straightening Jig
Ha I’m afraid so. Best John
- Last Name: Schwab
Hey John, this is your new friend Dave. When are you moving to Ohio??
LOL, well my 1st cousin lives there, he’s about to retire from the USAF & has decided to stay in the cold Midwest. I suppose I’ll need to find the front saddle before I can do anything ha
- First Name: Donnie
- Last Name: Brown
John. Nice looking jig. You will need to find and install the "taper pins" in the tail shaft for the cone. The taper pins is what sets the alignment of the tail shaft. There should also be 2 taper pins in the front plate for the hand crank test pin. Without the taper pins there is no accuracy. McCaster Carr has the little pins for the top of the table. It takes 10 pins but buy 20. They are cheap and you will break them from time to time. If you buy the McCaster Carr pins you must aneal them by heating them up to a "dull red" and let cool slowly. As sold they are too hard. Of the ten pin holes 6 of them go all the way thru the table. A broken pin can be driven on thru the table no problem. The other 4 holes are blind holes. If you do not areal the pins it is very very very difficult to drill the broken pin for removal. Trust me on that one. If you need any info on where to get the few missing test pins, give me a call.
I have several new friends since I got my pan jig
Donnie I’ll call you in the morning or you can call me. Got a bunch of questions, Matt will be happy to know we can get the pins. Best John
- First Name: Randall
- Last Name: Strickland
Mark I use a weed burner to heat block as it heats a larger area and retains the heat better.https://www.youtube.com/watch?v=https:/ ... d3Hdqq6GSI
- First Name: Herb
- Last Name: Iffrig
Randal youtube says the video is no longer available.
