drive shaft tap
Topic author - Posts: 63
- First Name: Tom
- Last Name: Leroux
- Board Member Since: 2010
drive shaft tap
WTB drive shaft tap 13/32x16 tap
tom
tom
- Last Name: Hatch
Re: drive shaft tap
I may have an extra one. I will look. Email me
- Last Name: Hatch
Re: drive shaft tap
I don’t have an extra one.
I may look into making another batch if there’s interest. Dan
- First Name: Joe
- Last Name: Kowalczyk
Re: drive shaft tap
Dan, I’d like to buy one or two if you get them made
Regards,
- First Name: Tom
- Last Name: Leroux
Re: drive shaft tap
Dan
thanks I will buy 2 if you make them
tom
tom
Re: drive shaft tap
Have you measured the OD of a 3/8-16 helicoil/thread insert tap?
If I was home I would measure one. If you dont have one, take your caliper over to Hilco.
Something in the back of my head spoke to me. They arent as hard to get as you would think.
Edit: Further investigation. The helicoil tap would be to big. It would work for a 7/16-16 bolt (Harley)
I gotta learn to ignore those voices.
Re: drive shaft tap
Nothing wrong with trying to think outside of the box, John
- Last Name: Lemperes
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring
Re: drive shaft tap
Please excuse my ignorance but, what is a drive shaft tap used for?
Re: drive shaft tap
The axle housing halves have a "special" thread that the d.s. spool studs/bolts use
- First Name: Tom
- Last Name: Leroux
Re: drive shaft tap
I will Checking on having some Made.
stay tuned
stay tuned
Re: drive shaft tap
