Spotlight bracket
Topic author - Posts: 12
- First Name: Michael
- Last Name: Kinzel
- * REQUIRED* Type and Year of Model Ts owned: 1923 Pickup
Spotlight bracket
- Last Name: Kinzel
Re: Spotlight bracket
My pictures didn’t load. I’ll try to update from a desktop.
- Last Name: Patrick
If you want help, we’ll need a picture or two.
- Last Name: Kinzel
Back to the top with a picture of the spotlight and bracket
If you are not going to restore the light, [read ruin the original patina] it would not be too difficult to replicate the missing piece in flat steel, given a former for the curve and some heat. It would obviously look like a made replacement, which is part of its history. Even if you do restore it, the steel piece could still be nickel plated to match the rest.
- First Name: Val
- Last Name: Soupios
I have the same light on my '27 and it's well worth the effort to get the piece you need made up. I restored mine but didn't bother with the plating. Works great and the mirror is free of the usual vibration.
- Last Name: Kinzel
Thanks fellas. I have a 23 pickup that is loaded with patina. I'm doing my best not to add anything too fancy or shiny. I suppose I will test my fabrication skills and make the bracket.
