Epoxy?
kgibbo
Topic author - Posts: 50
- First Name: Kevin
- Last Name: Gibbons
Epoxy?
Doing an engine rebuild and found camshaft bearings epoxied in place! Why would this have been done and any recommendations for undoing it?
- Last Name: Tannehill
Re: Epoxy?
With a brass drift can you tap them forward? It may require trying to chip off the epoxy then tapping to break the bound.
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
Re: Epoxy?
Try a bit of heat to release the epoxy. No doubt was attempting to cure the infamous cam bearing knock…
