Epoxy?
kgibbo
First Name: Kevin
Last Name: Gibbons
Epoxy?
Post by kgibbo » Mon Feb 20, 2023 10:23 pm
Doing an engine rebuild and found camshaft bearings epoxied in place! Why would this have been done and any recommendations for undoing it?
Last Name: Tannehill
Re: Epoxy?
Post by JTT3 » Mon Feb 20, 2023 10:35 pm
With a brass drift can you tap them forward? It may require trying to chip off the epoxy then tapping to break the bound.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Epoxy?
Post by Kevin Pharis » Mon Feb 20, 2023 11:01 pm
Try a bit of heat to release the epoxy. No doubt was attempting to cure the infamous cam bearing knock…
