TT Truck Steering Gear Bracket
BUSHMIKE
Last Name: Cushway
* REQUIRED* Type and Year of Model Ts owned: 1925 TT, 1926 TT, 1926 TT
Post by BUSHMIKE » Tue Mar 07, 2023 10:58 am
Looking at the steering gear bracket on my TT, It sure looks to me that the design intent was a spacer bushing between the bracket and the frame. One was not present on my TT nor is one shown in the price list of parts in the TT section. The actual bracket bears casting number TT932, which is Factory No.TT996 and Part No. 3539C St. Brkt with bushing - truck. The catalog sketch shows the hole.
Is a bushing present on any of the TT’s owned by forum members here? I wonder if the bushing transmitted frame flex to the steering gear and led to breaking or cracking that upright section of the steering gear and was, at some point eliminated?
Dan Haynes
Last Name: Haynes
Re: TT Truck Steering Gear Bracket
Post by Dan Haynes » Tue Mar 07, 2023 11:09 am
A block of wood goes in that gap.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Tue Mar 07, 2023 11:33 am
There is a TT wood block. You can find it here.
https://www.modeltford.com/item/1106WB.aspx
dobro1956
First Name: Donnie
Last Name: Brown
Post by dobro1956 » Tue Mar 07, 2023 11:51 am
Moxie26
Last Name: Jablonski
Post by Moxie26 » Tue Mar 07, 2023 11:55 am
Mark posted the proper link for the steering bracket block. It's at the top of the page. The other items listed are what people purchased in association with that steering bracket block.
BUSHMIKE
Last Name: Cushway
Post by BUSHMIKE » Tue Mar 07, 2023 1:28 pm
Thank you all for the answer!
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Tue Mar 07, 2023 2:33 pm
Mike, you can figure out the size from the frame and bracket dimensions then make your own with some hardwood. Remember to chamfer the inner corners to fit the bend of the frame rail.
All the best.
BUSHMIKE
Last Name: Cushway
Post by BUSHMIKE » Tue Mar 07, 2023 3:41 pm
Thanx Adrian! Ive looked at 7 TT frames now that still have the firewall and steering attached. Not a one had the bolt that should be there even if the wood rotted away long ago.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Wed Mar 08, 2023 8:31 am
You really do need a block there. The steering bracket/frame connection is too flexible and can induce death wobble without the extra support.
Post by Original Smith » Wed Mar 08, 2023 11:02 am
There is also a cupped dust washer that goes on the end of the steering shaft before the nut.
Post by TXGOAT2 » Wed Mar 08, 2023 12:10 pm
It's important to use the hardwood block and all the original bolts. After running a new assembly a few dozen miles, re-check all fasteners and the pitman nut for tightness, then safety wire or install cotter pins where appropriate.
