No pictures
Topic author - Posts: 1142
- Last Name: Gould
No pictures
How come I can't load files (photos) like before? Nothings changed on my end.
- First Name: Tom
- Last Name: Rootlieb
Re: No pictures
Worked for me. Try it again Richard.
Re: No pictures
There you go. Perfect example. You have to shrink file content.
- Last Name: Gould
Re: No pictures
Every once in a while pictures won’t load and I have to downsize them. Funny thing though same size photos of something else won’t. Not all the time but occasional so I just resize and they work.
Re: No pictures
The down size works, even when others of the same size do post. What I don't get is why my initial photo, in a run of more, appears twice???
- First Name: Mack
- Last Name: Cole
Re: No pictures
Hey! Dollisdad, where is that? Looks like me another project!!
Re: No pictures
It's very rare, but occasionally I get the dreaded yellow triangle and the instruction to reduce the size of the file. I've found that if I make it just one pixel smaller, that works. That doesn't make much sense, but as long as it works I'm not going to question it.
- First Name: Tom
Re: No pictures
I like that color of blue, Richard.
- Last Name: Nunn
Re: No pictures
My phone (Pixel 5) has two photo ratios. The 16:9 will not post without reducing the maximum pixel count in either direction to 1200. The 4:3 posts without alteration.
- Last Name: Gould
Re: No pictures
Thanks Tom. It's a good look indoors and out of direct sunlight but looks like a purple blue in direct light. I don't know if I'd recommend it because of that. It's the Mercedes blue most everybody uses but without a black undercoat
Re: No pictures
It looks like that wheel would fit right on either one of my '13s with no problem, color and all!
