Cam bearings
Topic author - Posts: 62
- First Name: RogerA
- Last Name: Barrett
Cam bearings
Hey guys, does anybody pour babbit in old cam bearing shells? I know new ones are available from langs but I heard they don't fit well without repairing.
Re: Cam bearings
Try asking on the general forum, not here in the classifieds.
- First Name: Joe
- Last Name: Bell
Re: Cam bearings
Take a hose clamp and tighten old shell, fill it with babbitt, set it in the lathe and bore to size, it is no rocket science on them.
- First Name: DAN
- Last Name: MCEACHERN
Re: Cam bearings
Before you go to that trouble, clamp them together and make sure the OD is somewhere near 1.375/1.373. Old shells are not worth repouring if the parting lines are worn down, making them loose in the block.
- First Name: Bob
- Last Name: Shirley
Re: Cam bearings
Make sure the break in the iron shell looks like a fresh break and is not worn smooth. The little jig is not hard to build.
- First Name: Joe
- Last Name: Bell
Re: Cam bearings
As Dan said you do want to start with good shells.
