Dual advance distributor
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sun Apr 02, 2023 5:00 pm
Finally have it clamped on!
A copy of a design of mine from the’80’s.
Borg Warner automatic for my wife’s speedster!
Kaiser
First Name: Leo
Last Name: van Stirum
Re: Dual advance distributor
Post by Kaiser » Mon Apr 03, 2023 5:19 am
Now that's a first for me, an automatic behind a T engine, nifty setup ! ;)
Leo van Stirum, Netherlands
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Mon Apr 03, 2023 9:32 am
I’ve probably seen half a dozen of them over the years!
Post by TXGOAT2 » Mon Apr 03, 2023 9:45 am
Some vacuum advance units connect to manifold vacuum, but many connect to a special vacuum advance port on the carburetor which is near the throttle plate.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Mon Apr 03, 2023 7:47 pm
I will be connecting it to the intake manifold.
Tom Dove Jr
Last Name: Dove
* REQUIRED* Type and Year of Model Ts owned: 1925 Touring, 1925 parts car(?)
Board Member Since: 2022
Post by Tom Dove Jr » Tue Apr 04, 2023 5:24 pm
You’ve built this before? How much total advance did/will you run?
Tom
I have never let my schooling interfere with my education.
Education consists mainly of what we have unlearned.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Apr 04, 2023 6:41 pm
I haven’t researched that yet. Running a Prus head
Erik Barrett
First Name: Erik
Last Name: Barrett
Post by Erik Barrett » Tue Apr 04, 2023 8:39 pm
Vacuum advance units are almost always hooked to ported vacuum. This gives them advance from just off idle to part throttle and takes it back when the engine is working hard at wide open throttle.
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Tue Apr 04, 2023 11:11 pm
Vacuum advance is primarily a fuel economy feature. It allows more advance in the light throttle/low load than the engine would tolerate under load. The increased advance improves fuel economy. I’d be interested in hearing how this translates in a T. The centrifugal advance would have to come in pretty early.
Andy
Post by TXGOAT2 » Tue Apr 04, 2023 11:26 pm
I've had poor results with a street driven engine with centrifugal-only spark control.
The same engine/manifold/carburetor with a vacuum/centrifugal distributor with the advance unit connected to ported vacuum made a huge difference in overall performance and in throttle response.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Wed Apr 05, 2023 9:43 am
My previous one of the identical design has worked well for 40 years. The car is capable of 100 mph and is easy to drive (no spark management required). The 71 car it came from had it connected to the intake manifold.
BobD
First Name: Bob
Last Name: Doris
Post by BobD » Wed Apr 05, 2023 11:11 am
Nice work Les. What did you source the distributor from? Some of the Model A guys have retrofitted a '70's Honda centrifugal / vacuum advance distributor with excellent results. However, the supply of these distributors seems to be drying up.
