Several Small Steps in Getting the 27 Coupe Ready to Roll
BLB27
First Name: Bruce
Last Name: Brakke
Post by BLB27 » Sat Apr 08, 2023 9:05 pm
Photos showing those small steps.
The third photo shows the clip pin used instead of pin with a cotter key. They say this makes changing fan belts easier. Any concerns about a clip vs a cotter key?
It took a sanding of the fan shaft with 320 and 400 grit to get it into the hub.
Re: Several Small Steps in Getting the 27 Coupe Ready to Roll
Post by TXGOAT2 » Sat Apr 08, 2023 9:11 pm
Clip should be OK.
Post by Jerry VanOoteghem » Sat Apr 08, 2023 9:13 pm
The spring clip should not be a problem.
The your red coil wire looks as if it's coming really close to the pan bolt. If so, relocate it slightly so it won't short when you retard your timer. Of course, you really won't know if it's an issue until you set your timing.
Last edited by Jerry VanOoteghem on Sat Apr 08, 2023 9:29 pm, edited 1 time in total.
Post by Scott_Conger » Sat Apr 08, 2023 9:19 pm
...and the blue wire at "1 o'clock" should have it's screwed-on connector turned around 180...as it is, every time the timer is advanced, the wire is doubled over and going to be pulled tight and will soon fatigue and break.
Last Name: Patrick
Post by jiminbartow » Sat Apr 08, 2023 11:57 pm
It is very important that you video tape your first attempt at starting your T. You won’t regret it and you can post it here so we can share in your celebration.
