I need to do some carb repairs on my '17 touring car, but I'm not able to ID the carb. Hopefully I've attached a picture. I've added an arrow indicating a cap on the top, between the throttle shaft and the needle, that my help in identification.
Thanks for your help, Maury Dean
1917 Carburetor ID
m_p_dean@yahoo.com
Topic author - Posts: 59
- First Name: Maurice
- Last Name: Dean
- * REQUIRED* Type and Year of Model Ts owned: 1917 Touring Car
Russ_Furstnow
- First Name: Russ
- Last Name: Furstnow
- * REQUIRED* Type and Year of Model Ts owned: 1911 Torpedo,1913 Touring, 1914 Runabout, 1915 Coupelet, 1916 Coupelet, 1917 Coupelet
Re: 1917 Carburetor ID
Kingston #6100 Model L-2, Used in 1917 and 1918. I hope this helps, Russ Furstnow
m_p_dean@yahoo.com
- Last Name: Dean
Thank you, Russ
Rebuilding the L-2 Instructios https://modeltfordfix.com/rebuilding-th ... arburetor/
Lots of info on Kingston Carbs scroll down to the L-2 https://modeltfordfix.com/the-kingston- ... el-t-ford/
- Attachments
- DSCN3028.jpg (47.55 KiB) Viewed 1042 times
