Engine serial number
				johnernst
Topic author - Posts: 40
 - Last Name: Ernst
 - * REQUIRED* Type and Year of Model Ts owned: 1922 Canadian Touring
I have recently purchased a 1927 Model TT and am doing a bit of research on it. The engine serial number is SC749255. Obviously the C is Canadian but I dont know what the S is for. Also the number is much higher than known list of Canadian engine serial numbers. Does anyone have any further information? Thanks John Ernst
Re: Engine serial number
Looks like a re number job.
Look around here for other number stampings & compare.
 - Last Name: Hatch
Look on frame under passenger door. Should be a number there. Should match engine number. If not engine has been changed.
To say that the "C" is obviously for "Canadian", is a leap of faith. It's a renumber job. Like Dan said, check the frame # and that will be what the original engine sported, too.
Edit 4/27 7:28PM
enough evidence presented to believe that the "C" either was original or is possibly intended to mean "Canada". My original post is flawed. Still believe it is a renumber job, though.
													Edit 4/27 7:28PM
In the encyclopedia Bruce doesn't mention S being on Canadian engines, which he would certainly have done if it had been a factory practice. In the USA replacement blocks were sold without serial numbers, with the expectation that they would be stamped with the number of the presumably ruined engine they replaced. If the same thing was done in Canada, I gather this is one of those replacement blocks.
Canadian? Number is too high.  SC749255  also the reasonable presumption that the S extra & the C is for Canadian, rather than the SC stud for something itself- SeCond, Smith's Car service
Restamp / cover up?
Looks like a 4 and its not the same shape (top^). Different 9 --- but not enough Canadian engine number stamps to conclude anything. What would be interesting is to see what the size of the casting area above the water inlet is for a late Canadian Block for comparison
Restamp / cover up?
John - hate be be a "Betty Bummer" but that engine is earlier & not a '26 - '27 !
Perhaps I misspoke - looking at your carburetor thread, I see the "Made in Canada" on the head - does it have the wide clutch & brake pedals ?
				Les Schubert
 - First Name: Les
 - Last Name: Schubert
Is Made in Canada cast on the block?
				johnernst
 - Last Name: Ernst
It does have wide pedals. I will look for "Made In Canada" on the block
J
						J
				johnernst
 - Last Name: Ernst
Steve Bruce McCalley does mention in his book
"Generally all Canadian engine numbers begin with "C" but some exceptions seem to appear, with "HC" and "SC" being noted, as well as some without any letter.
But perhaps it is a replacement engine, not sure,
J
J
Mark Nunn
 - Last Name: Nunn
The block has Made in Canada on it. See the carb thread photo.
				BUSHMIKE
 - First Name: Mike
 - Last Name: Cushway
 - * REQUIRED* Type and Year of Model Ts owned: 1925 TT, 1926 TT, 1926 TT
What I see is a double stamp. Very common with hand held stamps. The “shadow stamp” being a poor first hit or a bounce. To me the double spacing and characters all match.
				BUSHMIKE
 - First Name: Mike
BEAUTIFUL TT John!
				John Codman
 - Last Name: Codman
I agree with Bushmike. It is a beautiful T. On my '27 the frame number is accessible by removing the floorboards The number is stamped on the top frame rail just ahead of the right door opening. I am however, assuming that this would be the same for Canadian T's.
