Axle shenanigans
M.Sinclair
First Name: Matthew
Last Name: Sinclair
* REQUIRED* Type and Year of Model Ts owned: 1921 Coupe
Axle shenanigans
Post by M.Sinclair » Fri Apr 28, 2023 10:32 am
Hello, I am in the beginning of doing a front end rework and when I got the axle off I noticed that the top of the “forks” the spindle goes into and rides on are severely dished on both sides. What is advised in this situation, I had thought of welding on excess material and then milling it to flat original dimensions, however I have no clue what is supposed to be done here or even if it’s a problem.
Regards,
Matt
Re: Axle shenanigans
Post by John kuehn » Fri Apr 28, 2023 11:26 am
Some have done what you’re talking about and others have machined or filed it flat then used a washer to make a shim. Still others have gotten a better axle. Shimming will work OK just make sure you get a good fit when you add new bushings.
And as always others will tell you it’s a farm fix and so on.
You could machine a completely new bushing and make up the worn difference of the axle and add that to your new bushing. Good luck.
More than one way to skin a cat as they say.
Post by Mark Gregush » Fri Apr 28, 2023 11:36 am
The flange on the replacement bushing might be thick enough to fill the gap after facing. Face the dish to make flat on the bushing sides (there was/is a tool for that). If the gap at the bottom is too large with spindle installed, install a brass thrust washer to fill the gap. Most of the wear is on the underside of the top, the axle sits on the spindle, which can leave a gap at the bottom. Don't make the gap too small. When you tighten the spindle bolt and nut, you don't want to pinch it, can make for interesting steering! ;)
