Rear wheel grease retainer
dang.1922
Topic author - Posts: 57
- Last Name: Greger
Has anyone ever encountered this type of grease cap? I am assuming that it is an old accessory and not something currently manufactured. Dan
Re: Rear wheel grease retainer
Dan
That is an in the day retainer to keep grease off the rear brake shoes, mfg. by Dependable, they also made steel asbestos lined emergency brakes shoes.
dang.1922
- Last Name: Greger
Thank You Dan for the information, it seems to have worked and stayed on. Dan
I have one in a box someplace in parts storage.
Craig Leach
- First Name: craig
- Last Name: leach
I picked up some of that style thinking they could be rebuilt & used over & over again. Unfortuneatly all the ones I picked up are for late
axles & the ones I'm working on are early. My thought was they would not come loose like the Ford ones do. Then someone asked my if I
was putting the felt in between the cap & hub. Da I had never taken a rear end apart that had them. It makes sence to me thats why there
is a groove on the inside of the hub for it to fit in.
Craig.
Craig.
