Is this for Model T?
dykker5502
First Name: Michael
Last Name: Deichmann
Post by dykker5502 » Thu May 04, 2023 8:52 am
When I bought my pick-up this followed it:
I think it is something you mount on the tie rod (but where will the ends be? At the axle?) to limit wobble and shimmy.
Ford Model T 1914 Touring
Last Name: Humble
Board Member Since: 2006
Re: Is this for Model T?
Post by Humblej » Thu May 04, 2023 9:11 am
You have the right idea, it looks like an aftermarket antishimmy or steering stabilizer. It clamps to the tie rod and the ends would ride in the channel of the axle. Snake oil, I do not recommend using it.
Post by TXGOAT2 » Thu May 04, 2023 9:12 am
It is. It's not needed for a car in good shape.
Post by Steve Jelf » Thu May 04, 2023 12:14 pm
It is an aftermarket device used to wear grooves in your steering linkage.
