Howdy blokes
A thought occurred to me while pondering laced wire wheels, that while there are new beaded edge rims available, would aluminium be a reasonable choice to make them from?
We always plate original rims with a silver cad finish as they used to be, but anodised alloy would arguably be an even longer lasting finish, assuming you don't wreck them with tyre levers.
I realise unsprung weight isn't the be all and end all in T Ford motoring, but it certainly does help with bicycles, they've had alloy rims forever.
Cheers
beaded edge rims... in alloy?
Topic author - Posts: 7
- First Name: Anthony
- * REQUIRED* Type and Year of Model Ts owned: 1924
- Board Member Since: 2012
- Last Name: Humble
Re: beaded edge rims... in alloy?
If I can remember my metallurgy class from college, steel has a modulus of elasticity of around 200 GPa, where as aluminum has a modulus of elasticity of around 70 GPa. So to duplicate the properties of a steel rim with an aluminum rim, the aluminum rim would have to be about 3 times thicker than the steel rim.
- First Name: Terry
- Last Name: Woods
Humblej wrote: ↑Fri May 12, 2023 10:53 amIf I can remember my metallurgy class from college, steel has a modulus of elasticity of around 200 GPa, where as aluminum has a modulus of elasticity of around 70 GPa. So to duplicate the properties of a steel rim with an aluminum rim, the aluminum rim would have to be about 3 times thicker than the steel rim.
[/quote} Sounds reasonable. That's why automotive rims cast out of aluminum are much thicker than comparable size steel rims. Some aluminum rims used for racing are not, but they are not usually cast, but forged or manufactured differently.
- First Name: Les
- Last Name: Schubert
I just sold a pair of sports car wire wheels with aluminum rims. Certainly the rims were thicker than the other pair with steel rims, but they weren’t rusty!
I realise that aluminium is softer but there are some with high temper and the surface finish is certainly harder after anodising, in fact it's positively slippery compared to mill finish aluminium.
There are lots of modern 3 piece racing wheels that use aluminium rims, obviously because they're light weight. I've never put a calliper on them to determine material thickness though.
I imagine rolling and welding(?) a T rim could be quite different.
