print size
Scott Owens
Topic author - Posts: 4
- Last Name: Owens
- * REQUIRED* Type and Year of Model Ts owned: 1925 TT C-Cab 1927 Coupe
print size
Hi Chris, First I want to thank you for what you are doing. As some of the forum users are getting a bit older we need larger print for easier reading. Iam having trouble finding out who the poster is. I liked the print size of the old forum as it made reading a breeze. Can you think about increasing the print size to help out the older folks? Thanks, Scott
John.Zibell
- Last Name: Zibell
Re: print size
You may want to send him a PM. I doubt he has time to look at all the topics.
1926 Tudor
Jepprop
- First Name: Jack
- Last Name: Pergande
- * REQUIRED* Type and Year of Model Ts owned: 1924 Coupe
Re: print size
You can make the print larger on any page yourself by hitting ctrl+ (control plus) both together on your keyboard. You can do it several times to make it as big as you need. To make it- smaller you hit ctrl- (control minus)
Re: print size
You can also use this menu above the composition box to adjust the type size of your post.
Of course that doesn't affect other posts or the profiles. You'll have to use Command+ for that.
Scott Owens
- Last Name: Owens
Re: print size
Thanks guys, I forgot about ctrl +. It makes everything larger and I can move around and it stays the size I want, Scott
Doug
- First Name: Doug
- Last Name: Money
- * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor
Re: print size
And Ctrl "0" puts it back to normal size when you are done.
