Gaskets
JBog
First Name: Jason
Last Name: Bogstie
Gaskets
Post by JBog » Tue May 23, 2023 4:27 pm
In general, do you really need any gaskets on the model T? Other than the head gasket, couldn’t you just use various permatex products where you would use a cork or cardboard gasket?
Re: Gaskets
Post by speedytinc » Tue May 23, 2023 4:44 pm
Between the crank case, block & HH. Gasket thickness is needed to keep the crank center distance. Some gap would be needed.
Could possibly be done with a thick silicone bead. Specifically the 4th main fitting.
Re: Gaskets
Post by Mark Gregush » Tue May 23, 2023 5:13 pm
Gaskets aren't that costly. You can order just the gaskets you need from Lang's. I would not order the set, they come with too many extras, but you can buy a set if you want without the head gasket. Some locations as Scott suggested, do need the correct thickness of gaskets. In addition to the pan & hogs head felt, the timing cover needs a thin paper type gasket. You would also need the manifold gaskets. Last report was that the copper crush rings were out of stock at some of the dealers.
