Torpedo firewall bracket
Topic author - Posts: 525
- First Name: Andre
- Last Name: Valkenaers
Hi All,
I am working on a 1911 Torpedo.
To do the job right I am looking for the firewall to frame bracket set.
In the parts catalog from Chaffin's Garage I found the part number for these brackets 3640/41T.
Since a few days I am trying to contact them for asking if they have them in stock but can't get an answer.
Maybe somebody out there can help me with that.
Andre
Belgium
Andre
Belgium
- Attachments
- torpedo brackets.jpg (39.05 KiB) Viewed 2641 times
Re: Torpedo firewall bracket
Just keep trying, they get pretty busy.
- First Name: Gene
- Last Name: Carrothers
Andre, Since you are calling from EU. I can get thru to Dave ask about the availability and relay back to you?
Check the timing of your calls. Let me know if I can help,,,
1912 Torpedo Roadster
- First Name: Andre
Please Gene,
If you can help it will be great.
Andre
Belgium
Andre
Belgium
- First Name: Andrew
- Last Name: Brand
Hi Andre
I have an original pair (not for sale - for my Torpedo). If you can't get them and need dimensions to make them, I can help.
Andrew
Andrew
- First Name: Andre
Yes Andrew,
It will be a great help if I had the dimmensions to make these brackets.
Selling yours should be easier, but ...
Have a fine day.
Andre
Belgium
Have a fine day.
Andre
Belgium
- First Name: Austin
- Last Name: Hovey
- * REQUIRED* Type and Year of Model Ts owned: ‘11 Torpedo
- Board Member Since: 2014
Andre,
I responded to your post last year on this with a few dimensions. https://www.mtfca.com/phpBB3/viewtopic.php?f=2&t=26704
Let me know if I can be of any other help with dimensions or anything else. I had detailed engineering drawings made for these brackets.
Austin
Austin
- First Name: Andre
Thanks Austin,
I couldn't find this post.
Do you have other messurment about these brackets?
I think the only way to do this right is to make the brackets myself but there for I will need good drawings.
Andre
Belgium
Andre
Belgium
- First Name: Gene
Andre, I just talked to Dave at Chaffins and he has ONE set of those brackets in stock. I'm not sure if you were using the New Number and allowed for the time difference? Chaffins new number is 1-951-226-7331, New address518 N Spring St Lake Elsinore, Ca. 92530
Hope this helps
Hope this helps
- First Name: Gene
Andre
You might also email them at support@chaffinsgarage.com Their hours are 8AM to 5PM Pacfic time Monday thru Friday
- First Name: Andre
Gene,
I just send a mail to Dave to order the brackets.
At This time I am in the South of France till next Monday and will try to get them on the phone.
Andre
Belgium
Andre
Belgium
- First Name: Andre
Thanks All,
Parts are on the way to us.
Thanks Dave to help .
Andre
Belgium
Andre
Belgium
