RPM vs.MPH Graph?
Professor Fate
Last Name: S
* REQUIRED* Type and Year of Model Ts owned: '23 and '26
RPM vs.MPH Graph?
Post by Professor Fate » Wed Jun 14, 2023 8:01 am
Does anyone have a graph depicting rpm vs. mph? Is 50 mph 2000 rpm in high gear? (TT truck, ruckstel, and warford excluded. Stone stock car only)
________________
**FATE**
Mark Nunn
Last Name: Nunn
Re: RPM vs.MPH Graph?
Post by Mark Nunn » Wed Jun 14, 2023 8:10 am
You have not provided enough information. Is this for your speedster? What is:
Tire rolling radius?
rear axle gear ratio?
Aux trans?
My runabout with my tires, 40/11 ring and pinion would turn 2054 rpm at 50 mph. But, it will only see that speed on a trailer.
Post by TXGOAT2 » Wed Jun 14, 2023 8:15 am
2000 RPM will give about 50 MPH in high gear with standard gearing. Actual tire diameter will affect actual speed.
200 RPM = about 5 MPH, 1000 RPM = about 25 MPH, etc
My car shows about 48 MPH @ 2000 RPM according to a Garmin device. The error may be due to an inaccurate tach or tire size or the Garmin device or even the set up of the ring & pinion or tire slippage.
FWIW, the Garmin device appears to be fairly accurate as to speed and location. It is not consistent with elevation readings.
I have 4.40/4.50 X 21 tires running at 24 PSI cold. Tread is well-worn on rear tires.
First Name: craig
Last Name: leach
Post by Craig Leach » Wed Jun 14, 2023 9:50 am
I found this on the Forum.
RPM vs Speed.jpg (53.73 KiB) Viewed 1495 times
Post by Norman Kling » Wed Jun 14, 2023 10:54 am
I don't think they are directly related. MPG will also be affected by the grade uphill, downhill, level. And it will be affected by the wind speed and direction. Also the weight of the vehicle and load. And will be affected by the condition of the engine. Too many variables.
