Hello,
I sadly might be letting go of a nice pair of 09 spindles. Any idea how much I should get for them? Any help appreciated. Picture attached.
1909 Spindle Pair value??
aajf
Topic author - Posts: 47
- First Name: Andrew
- Last Name: Fuller
- * REQUIRED* Type and Year of Model Ts owned: 1917, 1922
- Attachments
- imagejpeg_0(22)_(1).jpg (17.02 KiB) Viewed 1153 times
pete eastwood
- First Name: Pete
- Last Name: Eastwood
Re: 1909 Spindle Pair value??
those are the one year only - 1922 "one piece" spindles. Kinda' rare.
they are different that the 1909 / 1910 "one piece" spindles.
ModelT46
- First Name: Darel
- Last Name: Leipold
They will fit a 1909-11 axle and look okay. I have had two sets over the years. Thoise than need one piece spindles for their 09-11 axle, prefer the correct ones. So, while rare, they should d used on a 1922 axle.
- Last Name: Tannehill
Darel, doesn’t the angle that the arms are positioned/cast limit the ability to turn on an early T set up? When I didn’t know anything about early Ts I bought a set of those for about $250 and didn’t discover the difference until I mounted them on an early axle couldn’t get them to work. Unfortunately I also straighten the arms trying to make it work.
