My neighbor had a problem
Topic author - Posts: 477
- First Name: G.R.
- Last Name: Cheshire
The tire on his work wagon looked like this
He said none of the local stores had a tire that matched exactly, but he could either get one through amazon and wait 2 weeks (coming from China) or replace all 4 at a cost of $100+. He asked if I had any ideas... I said grab me a couple of pieces of that scrap plywood. This is what I came up with
I may make a model t'er out of him yet!Do it right or do it over,your choice. Drive like everyone is out to get you!
- First Name: Erik
- Last Name: Johnson
Re: My neighbor had a problem
Do you live near Harbor Freight?
They sell a comparable ten and thirteen inch wheels with the same style pneumatic tire:
https://www.harborfreight.com/search?q= ... ¤t=1
In the past, they sold replacement ten and thirteen inch tires and tubes seperately but apparently that is no longer the case. Two years ago, a neighbor discarded an expensive, heavy duty hose-reel because one of the four tires was shot. I bought a replacement tire for a few dollars at Harbor Freight and sold the hose reel on Craigslist for over a hundred bucks.
Northern Tool is another option if you live nearby:
https://www.northerntool.com/search?f=B ... y=1&s=tire
- First Name: G.R.
We have HF and NT within a mile but all the tires had 1/2" or 5/8" his wagon has 9/16" axles
Nobody had a 9/16" drill bit handy ?
5/8" and use shim stock.
- First Name: Austin
- Last Name: Farmer
If you wanted to keep the tire you might be able to fill it some sort of foam like construction foam.
Wont pop either!
Wont pop either!
- First Name: Mack
- Last Name: Cole
That is neat! Glad to see people are still capable of making do with what is around!
- First Name: Art
- Last Name: Mirtes
When I was 5 to 7 yrs old, I had a wagon which was built by my grandfather. The wheels were wood with sheet metal wrapped around the diameter which served as a tire. The wagon didn't ride very well, but i didn't know it at a young age,
Art Mirtes.
Art Mirtes.
