Heinz Coils Adjusting Points Help Needed
Topic author - Posts: 72
- First Name: Victor
- Last Name: Foster
- * REQUIRED* Type and Year of Model Ts owned: 1910 Touring, 1915 Touring
- Board Member Since: 2002
I have 4 Heinz coils I just acquired. My guess is these are original coils. 3 spark nicely in a buzz box. The 4th one momentarily sparks then stops. The points were upside down so I turned them over with the same results. The points close at about a 20 degree angle, certainly not parallel as they should be. I have no idea what to adjust to get them parallel, set the points, adjust the spring tension, etc. I've read everything I could find on Heinz coils and one of the articles implies the spring should be flat. What spring is that referring too? Any help, or guidance would be greatly appreciated.
- Last Name: Jablonski
Re: Heinz Coils Adjusting Points Help Needed
Just look up a previous posted topic about 3 weeks ago entitled "New style coils versus Old style coils". There is a poster that does rebuild and recalibrate Heinz ignition coils and I believe he would be your answer.......... David Woods, ............phone : 1-517-927-9232 . .......Forum name is " Woody23 "
Victor ...... any help yet with your coils ???
I thought Luke Chanell is the Heinz coil guy.
Post Luke's contacts for Vrayfister.
Luke.chennell@gmail.com
Midnight Coil Repair
1130 E. Euclid
McPherson, KS 67460
Sorry don't have a phone number. If you do the Facebook thing, he has a page under Midnight Coil Repair. I have found sending him a Facebook message seems to work the best. YMMV
1130 E. Euclid
McPherson, KS 67460
Vrayfoster .... Good morning... has posted information been of any help ?
- Last Name: Foster
Nope, I still don't know how to adjust the points on Heinze coils. I would like to find a write up like Patterson and Boggess did for the KW coils if one exists.
Good Luck Victor. Two quality contacts were suggested to help, up to you to accept.
https://www.mtfca.com/discus/messages/7 ... 1484321536
this will provide all of the clues and outright information to accomplish what you want to do, but a buzz box will not be part of testing the results
read carefully and thoroughly - these coils are not set up according to regularly regurgitated convention that applies to the bulk of later coils.
there is so much more to repairing or using a coil than "getting a good spark", and that "so much more" has been covered to pretty much the "nth" degree on the forum. A search on GOOGLE "Mtfca Heinze coil" will yield a plethora of information (much like the link I supplied above)
you're not working with the easiest coils, for sure, and unless fully tested, supplied with a replacement cap and excellent or reproduction points and adjusted correctly, they are going to be less than great performers (as a set). To achieve a high level of performance individually and then get them to perform adequately in the car as a "set", you're going to have to invest more $$ in test equipment than the cost to send them out for warranted rebuilding.
- First Name: Mike
- Last Name: Kossor
Here is another link I think you may find informative and of interest about Heinze coils.
viewtopic.php?f=2&t=26730&p=205560
