Universal Joint Rivets?
Topic author - Posts: 4231
I offered to re-rivet an otherwise very nice u-joint for a friend. Well... Got the 4 old rivets out. They're .266 diameter, 17/64". Does anyone know where to buy 17/64" dia. rivets? They probably need to be about 7/8" long.
Thanks!
Thanks!
Re: Universal Joint Rivets?
Try McMaster Carr https://www.mcmaster.com/products/solid-rivets/
They have a good selection
Also Grainger.com https://www.grainger.com/product/GRAING ... Head-6KE62
Jerry
I can't help but believe that a 1/4" rivet is the correct rivet that will swell up as it is set
MIL-R-47196 places max hole at .265 and honestly since this is not a battle ship, I think you're in the range
- First Name: K
- Last Name: Burket
Snyder’s lists dia of rivets they sell in small quantity on their website.
I have a bag of 1” .260” rivets if you’ll like some of these, email me an address and I’ll send you eight in the mail.
I was finally able to use these rivets. Want to say thanks very much for sending them. They worked great! I don't have an acetylene torch, so I did them cold. Still, they expanded nicely and are very tight. A good rivet setting tool was also a big help.
- Last Name: Hatch
You might want to look into one of these.
https://www.amazon.com/Solary-Flameless ... 9894&psc=1
I have one, works great for what you did. Dan
I had no idea such a thing existed. I read the reviews. Varied from "works great" to "caught fire". I might just be tempted! Thanks!Dan Hatch wrote: ↑Tue Aug 22, 2023 1:54 pmYou might want to look into one of these.
Neat tool.
My grandfather manufactured plomb wrenches during the war.
He heated the metal in the same way running steel bar thru a strong magnet.
To be clear. I've known about induction heating, but never knew of these hand-held portable units before.Jerry VanOoteghem wrote: ↑Tue Aug 22, 2023 2:05 pmI had no idea such a thing existed. I read the reviews. Varied from "works great" to "caught fire". I might just be tempted! Thanks!Dan Hatch wrote: ↑Tue Aug 22, 2023 1:54 pmYou might want to look into one of these.
- First Name: Art
- Last Name: Mirtes
I have seen a similar tool used to loosen gasoline line fittings. It worked well but I don't have one. I hope I never again have to drop a gas tank.
Art Mirtes
Art Mirtes
