Hercules Model C
Keith Daniels
Topic author - Posts: 80
- First Name: Keith
- Last Name: Daniels
- * REQUIRED* Type and Year of Model Ts owned: 1927 TT Truck, 1926 Touring
Hercules Model C
Picked one up at an antique store today, listed as a tire stretcher. I just got done going through past threads, at $22.50 I think I did pretty good.
It appears to be original paint, and what I read tends to agree. A little oil and I think we are good to go!
Distagon2
Re: Hercules Model C
You got a great deal. That tool makes tire work on split rims a piece of cake.
- Last Name: House
Good score. But that tool has ruined a whole lot of split rims when operators don’t follow instructions in its use.
BUSHMIKE
- First Name: Mike
- Last Name: Cushway
- * REQUIRED* Type and Year of Model Ts owned: 1925 TT, 1926 TT, 1926 TT
Where do I find proper instructions for its use?
These are general instructions I found
The red Y is to put the rim back in place (from a previous discussion)
Here is one set of instructions, similar tool.
- Last Name: House
Good save Frank. Those are the instructions I posted last year..
Keith Daniels
- First Name: Keith
So basically you push apart with the screw leg just off to the solid side of the tab, then to pull together you flip it so the screw hook is directly across from the split, and the two legs are equal distance from the split?
