Clutch meltdown
Erik Barrett
First Name: Erik
Last Name: Barrett
Clutch meltdown
Post by Erik Barrett » Fri Jul 14, 2023 3:53 pm
Saw a new one today. Someone worked on this 1913 engine and used the best of everything, including a new brake drum. So far, so good, but they neglected to install the replaceable shoes on the clutch lugs. Clutch bound up and it was nearly impossible to crank the car. I hope I can save the expensive new drum by putting on the shoes.
Re: Clutch meltdown
Post by Jerry VanOoteghem » Fri Jul 14, 2023 4:13 pm
Erik,
I'm thinking that maybe the lugs are too worn down to be properly gripped by the shoes. Also, the voids left under the shoes may not leave them well supported enough prevent distortion/cracking/loosening. Hope I'm wrong.
Re: Clutch meltdown
Post by speedytinc » Fri Jul 14, 2023 4:26 pm
I worked on a 13 with the same situation. "grandpa" rebuilt the transmission 40 years before.
The crime of it was he found a late new NOS narrow drum & didnt put on the shoes. :roll: :roll:
The recent caretaker brought a box of extra parts. In among the used junk was ANOTHER NOS late narrow drum. :o
Yes the disks get jammed up in the drum's shoe notches.
Joe Bell
First Name: Joe
Last Name: Bell
Re: Clutch meltdown
Post by Joe Bell » Fri Jul 14, 2023 4:47 pm
Can you say SHIT!
First Name: Henry
Last Name: Lee
Re: Clutch meltdown
Post by Henry K. Lee » Fri Jul 14, 2023 7:21 pm
You are kidding me..., Really?
Erik Barrett
First Name: Erik
Last Name: Barrett
Re: Clutch meltdown
Post by Erik Barrett » Fri Jul 14, 2023 8:10 pm
No kidding. I had to jack this thing up to get it running and it was a dog in low gear. Once I got it into high and the clutch was no longer involved, everything was fine.
Dennis_Brown
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Re: Clutch meltdown
Post by Dennis_Brown » Sat Jul 15, 2023 10:57 pm
Is this a cast brake drum or one of the new steel ones? If is one of the new steel ones could it be welded up with a wire feed and dressed back down? It might be a little time consuming but if you are just going to scrap it, it might be worth the try.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: Clutch meltdown
Post by Dan McEachern » Sun Jul 16, 2023 2:13 am
The new brake drums are not steel, they are ductile iron. Welding on this is not a real good option.
Kerry
Last Name: van Ekeren
Re: Clutch meltdown
Post by Kerry » Sun Jul 16, 2023 2:59 am
Doesn't look damaged enough to affect the fitting of the shoes.
Erik Barrett
First Name: Erik
Last Name: Barrett
Re: Clutch meltdown
Post by Erik Barrett » Sun Jul 16, 2023 1:48 pm
The drum is fine. I dressed off the damaged areas and installed the shoes. It’s going back together today.
BobUkPipedream
Last Name: Dyer
Re: Clutch meltdown
Post by BobUkPipedream » Sun Jul 16, 2023 5:04 pm
I’m confused as I thought these shoes were just for 1926-27 cars? I am about to put my 1923 together and there is no space for shoes, and they had none when I took it apart. I had to file the notches out but they were not too bad. The Mike Bender videos do not shoe any shoes either.
Kerry
Re: Clutch meltdown
Post by Kerry » Sun Jul 16, 2023 5:23 pm
Bob, this is a modern made replacement drum.
Re: Clutch meltdown
Post by DanTreace » Sun Jul 16, 2023 5:29 pm
The new modern small trans brake drums are made in the pattern of the late '25 which did have shoes, that were later same on the large 26-27 trans brake drums. Good idea for the new drums so they can be reused if the clutch discs wear the lugs.
These are J&M brand new.
