1924 tailight operation
Art Ebeling
Topic author - Posts: 511
- First Name: Art
- Last Name: Ebeling
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring 14 runabout
I am working on a 24 Touring. It has a new wiring harness and a new ignition switch. The tailight only comes on when the switch is turned to “on” but not on “dim”. Should it be on in both positions? Thanks, Art
Re: 1924 tailight operation
Yes. The outer ring inside the switch will make contact as indicated, green, in this diagram. The brass colored contacts are riveted to a steel ring providing continuity. In the diagram one is in contact with the BAT connection & the others are DIM Tail or Bright Tail. What do the headlights indicate?Art Ebeling wrote: ↑Wed Jul 26, 2023 5:25 pmI am working on a 24 Touring. It has a new wiring harness and a new ignition switch. The tailight only comes on when the switch is turned to “on” but not on “dim”. Should it be on in both positions? Thanks, Art
Check for continuity on the Tail screw when the switch is on dim (one lead on DIM & the other on Tail) no wires connected. Its possible that the lower U is not making contact
