Hood latch tool
Erik Barrett
First Name: Erik
Last Name: Barrett
Hood latch tool
Post by Erik Barrett » Tue Aug 01, 2023 5:15 pm
We are putting a 1913 back together after clutch replacement. Facing the dreaded hood latch installation, my friend Michael had an idea for a tool to assist, and a great one it was! He made it out of a $10 pair of Harbor Freight vise grips and a flat washer. About five minutes later, all the latches were in. Even the one right next to the carburetor was a breeze. I did the rear ones from underneath.
Re: Hood latch tool
Post by DanTreace » Tue Aug 01, 2023 5:59 pm
Clever tool!
Yep, those hood latches are a bit of a struggle.
So I just used plastic wire ties, they compressed the spring, placed the hood latch.
Then, with the help of micro hemostats, griped the washer and cotter, slipped up the washer and cotter pinned the assembly.
Finally, cut the wire tie to free the spring to do its work.
Worked out real nice :D
Last Name: House
Re: Hood latch tool
Post by George House » Tue Aug 01, 2023 6:05 pm
What a good idea Erik 👍 thanks for sharing it 😁
Re: Hood latch tool
Post by Allan » Tue Aug 01, 2023 6:22 pm
The difficulty is largely caused by the ridiculously strong springs sold for the job. I ditched them in favour of some far less aggressive ones from a spring selection kit. These are much gentler on the hood, especially the alloy hoods on early cars.
Re: Hood latch tool
Post by speedytinc » Tue Aug 01, 2023 6:28 pm
If you use AN washers, as per original type, The latches are assembled to the hood shelves, then installed as a unit.
No contorting to work within the frame rails.
Erik Johnson
First Name: Erik
Last Name: Johnson
Re: Hood latch tool
Post by Erik Johnson » Tue Aug 01, 2023 6:46 pm
Like Allen Down Under, my father and I installed lighter springs on our latches so there is less tension.
