FS: Taper Leaf Front Spring
Topic author - Posts: 2939
- Last Name: House
Its peculiar. That’s why only $100 + the ride. Bolt holes only in main spring and top 2 springs. None in other 4. Oiler holes both ends of main spring. See 2 tabs riveted to fifth leaf…. gwhouse731(at)gmail.com
Ken Buhler
- First Name: Ken
- Last Name: Buhler
- Board Member Since: 2012
Re: FS: Taper Leaf Front Spring
George,
I have one like that with the clamp riveted. Others have the curled leaf for the clamp bolt. Does your center bolt not go through?
Work honestly
Stay true to your word
Get the job done right
- Last Name: House
Yes. Thats why I called ‘peculiar’ and priced it accordingly. I’ve seen springs like this with bumps centered on each leaf - but not this spring. The top 2 leafs might’ve come from a spring with a bolt. I guess the center 4 might have to have a center hole drilled. Looks like it may be going to Australia.
- Last Name: House
Yep… Thanks Bill and MTFCA. It’ll be driving on the left side of the road
