What have you done to your Model T in August?
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Sun Aug 06, 2023 5:12 pm
Not much...it's too hot even at 8:00pm.
Then again, I had to get some stuff done.
Vern (Vieux Carre)
Last Name: Hjortnaes
Re: What have you done to your Model T in August?
Post by DHort » Mon Aug 07, 2023 2:00 am
Thursday I drove about 20 miles to a local car show, so I could hand out flyers to my car show next month. Met a lot of nice people, an old friend, and took a young couple for a ride.
Saturday I went on a tour with the Dairyland Tin Lizzie group and added another 130 miles. A young lady in the group was able to drive a Model T for the first time, so it was called Lilly's Lizzie Tour. We stopped at a cheese factory for some cheese, visited a Victorian Mansion, ate lunch, and then stopped for ice cream on the way home. Later that day our neighborhood had it's annual block party and I gave rides to about 20 kids and a few adults. Some kids must have gone around the neighborhood 4-5 times.
Later this week I head up to Minneapolis area for the New London to New Brighton Antique Car Run. I will try to post a few pictures. I know others will, too. www.antiquecarrun.org
NealW
First Name: Neal
Last Name: Willford
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1929 Model A Tudor
Post by NealW » Mon Aug 07, 2023 7:41 am
The heat wave, in Kansas at least, finally broke this weekend. My wife wanted to go T driving, so how could I say no? I think we won the award Saturday for "the oldest car to get gas at Casey's on 8/5/23"
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Mon Aug 07, 2023 8:40 am
I finally installed the transmission screen in my Runabout. The transmission door was installed inside out. It should have been obvious to cousin Bo (who assembled the engine in the '80's) that the painted side goes out, not in. Everything I could see inside looks good. That was a pleasant surprise.
Post by Rich Eagle » Mon Aug 07, 2023 10:31 am
I felt good enough to do some work in the shop after my 2-week health break. The spare tire on the Coupe had lost air so I put on a good one. I left my reflector bar off as it makes changing tires more time consuming. These Riversides I got from Rich B. in the '60s are great spares. I wouldn't buy whitewalls, but his all-white paint job looks great these days.
I noticed my taillight needed refreshing. The plastic window disintegrated, and the white cardboard reflector warped out of shape. I think these were standard and they do make the taillight brighter. I also resoldered the socket as it was loose. I made sure there was a good ground to the spare bracket.
The wire insulation was frayed so I refreshed it with "friction tape".
The light didn't come on so I will check the bulb and connections soon. It was nice to be doing some work again.
Last Name: Seth
Post by perry kete » Mon Aug 07, 2023 12:27 pm
Rich,
Sorry to read that you have had health issues but I'm glad to see your out tinkering again on the cars.
Best wishes
Denny
Post by Rich Eagle » Tue Aug 08, 2023 5:44 pm
Thanks Perry. The good doctors here have kept me alive for 33 years and I hope for that many more. I'm almost 76. We all have to take our turn. Meanwhile, the forum is some of the best medicine going and I enjoy it almost every day.
Thank you all for that.
I got the taillight to work. The plugs have been exposed to the outdoors, Summer and Winter for 10 years now. They fit tighter into the sockets and have some corrosion and dust in them. I think these are old originals. I wiped with lacquer thinner and scuffed with Scotch pads and they fit better now. The headlight plugs needed it too and work fine now. Grounding is also a problem with outdoor cars.
My cars that sit outdoors show me many things that are problems and some that really are not, that I wouldn't know about with the pampered indoor cars. This gives me better insight into what owners contended with back in the day. I thoroughly enjoy that. Something many don't get to know.
Last Name: Strange
Post by CudaMan » Tue Aug 08, 2023 7:24 pm
My ignition switch had started acting up the past couple of drives, so I removed it yesterday, cleaned the contacts, and bent them up a bit so that they press harder into their pockets. :)
Distagon2
Post by Distagon2 » Tue Aug 08, 2023 10:24 pm
Took my 1912 pan to Brent Terry's shop in Elizabethton, TN for him to check it out on his pan straightening table. Now is the time to check it and correct any deficiencies.
Post by Rich Eagle » Fri Aug 11, 2023 4:23 pm
Sometimes it's nice to have a lazy day out in the shop without urgent projects. Today I rearranged the clutter a bit.
The lighting on the Coupe reminded me of how bad the body panels were. I can't imagine trying to get them straight enough for black paint.
I cleaned a few parts including this fan grease cup and pondered how they made it and when. It was on a brass hub fan, but I suspect those were brass cups and bases. I'm not sure which years these were used. I have seen cup bases with the rubber seal before and thought what a good idea it was. The different shapes of the clamp areas are interesting. Does anyone know when and where else Ford used them. There are many cups without the rubber seal.
Anyway, the weather was great and garage time is always good.
Post by Rich Eagle » Fri Aug 11, 2023 4:34 pm
Looking further, I see this on FordFix.
I hadn't ever heard of an aluminum cup before???
Last Name: House
Post by George House » Fri Aug 11, 2023 4:38 pm
What I did on my Model T today ?.. Well, I walked out to the shop, saw 108* on the thermometer, and walked back into the AC house 😎
Post by speedytinc » Fri Aug 11, 2023 4:59 pm
Dont believe everything you see on the internet.
Those internal threaded cup bases were only used on early fan shafts as shown.
The seal is a crimped leather ring. The leather seal can be replaced with an O-ring.
The leather acted as a seal & tensioned the cup to not vibrate off.
walber
First Name: Walt
Last Name: Berdan
Post by walber » Fri Aug 11, 2023 6:53 pm
Busy month so far. Frame cracked between engine side mount and body mounting bracket on my speedster on an 800 mile tour in late June. Body here, engine there, front and rear axle assemblies over there along with a bunch of misc. parts. Finished reassembly and fired it up last Friday morning (Aug 4th), drove it to Oregon for a 100 mile endurance run on Saturday and a 146 mile tour on Sunday and drove back home on Monday. GPS showed 852 miles over the 4 days. I took Tuesday off. Tour day was all paved but on great roads. Hot 100 run was a great route with very little traffic and fine scenery but lots of gravel. I've got a lot of cleanup to do as the dust and some leaking oil made an ugly mess. Time to take care of some minor maintenance and change 2 tires before a 200 mile endurance run on Sept 3rd. Oh, and my Model A wants a little clean up and attention as well. Sure glad I'm retired.
Tbird
Last Name: Bird
Post by Tbird » Fri Aug 11, 2023 7:37 pm
Finalized the patterns for the “C” for the Delivery Car, and gluing up the maple boards to finish off the C pieces.
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Fri Aug 11, 2023 7:55 pm
We took the 25 to the freeport thresheree last wekend. Got to drive. :D
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Sat Aug 12, 2023 2:07 pm
Turned some drive plate pins
the originals where to sloppy for my liking
19/64ths did the trick
Just enough to get everything the same size
A nice tight fit with enough clearance for oil
I will finalize later when I buck them tight
Bryant
mtntee20
First Name: Terry & Sharon
Last Name: Miller
Post by mtntee20 » Sat Aug 12, 2023 5:31 pm
Spent a NICE day at the Wheatridge Heritage Center, Baugh House. This is the first house in the Wheatridge area. Originally a log cabin. Later, they built a Victorian hose around/over the original log cabin. You will see the original log cabin while touring the house.
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Sat Aug 12, 2023 7:29 pm
Drove the RPU to the gas and steam show in the next town. Nothing better than gravel roads and a Model T on a nice day.
Jim11787
First Name: Jim
Last Name: Sarc
Board Member Since: 2023
Post by Jim11787 » Sat Aug 12, 2023 10:40 pm
Rebuilt Leakey carb, replaced sediment bowl valve and fuel line and installed a fuel filter. Next up is to replace stripped stud on coil box and replace the contacts in the coil box as soon as the parts arrive.
Also replaced crummy spark plug wires and a new timer harness with proper routing and clips to secure it.
Arbs
Last Name: A
Board Member Since: 2022
Post by Arbs » Sun Aug 13, 2023 9:49 am
Went to the drive-in then pulled the radiator the next day, due to a leak.
Gracie'sDad
Last Name: Dow
Post by Gracie'sDad » Mon Aug 14, 2023 5:38 pm
ICE CREAM!!!!!!!!!!!!!
TMiller6
First Name: Thomas
Last Name: Miller
* REQUIRED* Type and Year of Model Ts owned: 16, 24, 26 Touring - 26 Roadster and Fordor
Board Member Since: 2006
Post by TMiller6 » Mon Aug 14, 2023 8:42 pm
First, this wasn’t my car, it belongs to my son. He missed the 2022 Old Car Festival because his Heinze coil box went dead. This summer I disassembled the box and replaced three contact springs and the copper wire leading to each. The shop next door to mine shares a wall and the “farm” inside caused havoc with the humidity in my place and the machinist two doors over. Wholesale prices dropped and they moved out and all is now well. I’m happy to say the new guy next door is great.
So, After reassembling the box and soldering the wire to the split rivets we heard four coils singing. Tonight we cleaned out his fuel system. My son was so delighted to hear his car run that he bought me a burger and a beer. My daughter’s son was helping so he got fed as well. He’s eight years old and has no intention of missing the merry go round Friday night at the OCF.
Tom Miller
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Tue Aug 15, 2023 10:32 pm
Got to painting the black parts.
It's a 100 footer.
I looked for steel replacement fenders and never found any. So, we patched up what we had.
Vern (Vieux Carre)
RGould1910
Last Name: Gould
Post by RGould1910 » Tue Aug 15, 2023 11:06 pm
Just installed the horn. Finishing up mounting the tires and doing some touch up. Should be ready for the road soon.
frontyboy
First Name: dick
Last Name: dock
* REQUIRED* Type and Year of Model Ts owned: T sprint cars
Post by frontyboy » Tue Aug 15, 2023 11:24 pm
This was a twofer month, I just sold my 1914 roadster on the model t face book pages, and save the best for last, I now have in my shop my repurchase, the 1915 model t roadster known as the "Flying Dutchman" Very historic car powered by the famous and very rare Gallivan dual overhead cam engine. Now just waking it up from a long sleep. Hope to have it on the road next week. Once on the road, pictures will follow. When I bought the car back I got a very nice gold gilt desk sign which I will soon change my nick here to "Dr Gallivan.
frontyboy
NealW
First Name: Neal
Last Name: Willford
Post by NealW » Wed Aug 16, 2023 7:35 am
This week I moved our 1911 and 1915 to our new to us house. The house is about 3 miles from our old house, and it is not often that I drive both back to back within a few minutes of each other. The 3rd stall of the garage is more than double the depth of a regular stall, so there is even enough room for a 3rd T! I haven't told my wife that yet though. :lol:
It also has an 8' door, so it will be nice to be able to drive the touring car in and out without lowering the top. It will be the first time in years that I also get to park my "regular" car in the garage too.
Arbs
Last Name: A
Post by Arbs » Wed Aug 16, 2023 9:17 am
Looks great Neal! No drip pans under those beauties?
NealW
First Name: Neal
Last Name: Willford
Post by NealW » Wed Aug 16, 2023 10:11 am
I wish! I hadn't yet put them down yet when I took the picture. They came over in the moving truck later, and both had already marked their spot! This garage has an epoxy painted floor, which is easier to clean up than our old cement one!
tiredfarmer
First Name: leonard
Last Name: simunek
* REQUIRED* Type and Year of Model Ts owned: 1926 touring. 1931 model a pickup, 1947 willys cj2a
Post by tiredfarmer » Wed Aug 16, 2023 5:57 pm
This morning I backed Lizzy, my 26 Touring, out of the garage and gave her a good wash. I'm getting her ready for the Sooner Celebration we have every year in our town Waukomis a week from this Saturday.
RGould1910
Last Name: Gould
Post by RGould1910 » Fri Aug 18, 2023 6:49 pm
This afternoon I made a jig for locating screw holes to mount a Stewart 22 speedometer wheel gear on a freshly painted wood wheel. I used a Ford spindle and a 1/2 inch rod threaded on one end for an adjusting nut and drilled a quarter inch threaded hole for a pointed bolt on the other end.
The distance between opposing screw holes on the wheel gear is 6 and 1/2 inches. I drilled the quarter inch hole for the threaded bolt half that distance from the center of the spindle with the bolt installed in the spindle held in place by the nut. I cut plenty of threads on the end to make adjustments.
Post by Steve Jelf » Sun Aug 20, 2023 9:00 pm
A few months ago, half my turn signals quit working. The left turn side worked normally, but flipping the switch to the right got a faint flicker from the indicator. I assumed something had gone haywire in the control panel, so I took it out of the car to investigate. With all the outgoing wires disconnected I found that the control panel worked normally.
It didn't take long to find the broken insulation that was grounding out the right side. The arrow points to where some bare wire was showing and had been grounding the circuit.
Part of the reason for the cut insulation was that the wire going into the lamp was very tight in the hole, and pulling it in had made the cut. Originally I had drilled a ⁷⁄₆₄" hole, so I enlarged it to ⁵⁄₃₂". That allowed a new wire to slide in easily. Since learning about the mini-torch here on the forum, I've found it better than a soldering gun on a lot of jobs
The green lights are turn signal indicators. Both of them are flashing together, along with the red light, to indicate that the emergency lights are on. The blue light reminds me that the tail lights are on. Opposite that, to the left, is another blue indicator that isn't lit because it comes on when you step on the brake pedal. All these lights look washed out in a photo, especially the red, but in real life they are really red, blue, and green.
AandTman
First Name: Donald
Last Name: Vagasky
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster 26 Touring 25TT C Cab express 26 Ames Speedster
Post by AandTman » Mon Aug 21, 2023 2:26 pm
Finally got the screen sides and canopy done. The original door mechanism needs some fine tuning. Probably did not work that well when new.
Post by RajoRacer » Mon Aug 21, 2023 3:27 pm
Looking good Don !!! Someone on here was requesting info regarding the screen sided TT - yours is fabulous !
Post by Jerry VanOoteghem » Mon Aug 21, 2023 3:49 pm
Oh Donald, I really like that! :mrgreen:
su8pack1
Last Name: Kelly
* REQUIRED* Type and Year of Model Ts owned: 1925 Roadster
Post by su8pack1 » Fri Aug 25, 2023 11:28 pm
Just finished putting everything back together after completing a valve job. Starting it up tomorrow.
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Sat Aug 26, 2023 8:37 am
Celebrated Nellie’s 100th birthday a few weeks ago. Also installed a Miller Master Carburetor that I picked up at Hershey two years ago. It’s the first time I’ve had it going with this carburetor and I’m really impressed with the acceleration particularly going up hills. Also working on rebuilding various vintage generator cutouts.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Sun Aug 27, 2023 9:48 am
My generator only worked when it wanted to. It would put out about 1.5V at times. I was going to remove it to check the insides when I saw that the commutator contacts were sooty. I did a proper cleaning and polishing on them and it is working reliably again. With renewed confidence, we went to a small car show yesterday at a retirement community. We had six of our local club members there. (I forgot to get photos.) Our 30-mile trip was stressful. My Runabout's ignition kept turning off. I would mess with the position of the key to get it running again. The problem is obviously in the switch contacts. Since Ben Martin is not working in switches until October, I need another solution. My car does not have a magneto ring and only runs on battery. I think that I can add a jumper wire on the switch from Bat to Mag and use the Mag key position. It's worth investigating.
AndreFordT
First Name: Andre
Last Name: Valkenaers
Post by AndreFordT » Mon Aug 28, 2023 1:57 am
Hi Mark,
you can try the jump wire but... .
About five years ago I had a similar problem on my 1926 touring. Tried a few times to make a repair on the switch till I fried up the magneto by a short inside the switch.
Than I replaced the switch by a on-off-on switch and all the problems were over.
Good luck
Andre
Belgium
Moxie26
Last Name: Jablonski
Post by Moxie26 » Mon Aug 28, 2023 6:47 am
Rebuilt the foot starter switch, cleaned up contacts new gaskets back in June, replaced battery cables and starter with new 2/0 braided copper cables..... Starter spins a lot faster using the same 6 volt battery...... Now just need a little bit more time to get back into the system to install a battery cut off switch on the interior of the front seat riser in the 26, since access to the battery on the runabout is a bit tight thru the trunk.
su8pack1
Last Name: Kelly
Post by su8pack1 » Wed Aug 30, 2023 5:36 pm
Just installed the transmission oil screen and magnet.
Aussie16
First Name: Warwick
Last Name: Landy
Post by Aussie16 » Thu Aug 31, 2023 6:55 am
Finally received my new Anderson Timer and LED headlight globes that were on back order from Langs. The Anderson timer runs great, and I can see where I am going in the dark, just in case I get caught out past sunset. Those were jobs on my Fordor sedan. My 16' pickup had been leaking water on the shop floor. I removed the radiator and it has been at a nearby radiator shop for a few weeks. It was a new Brassworks radiator 10 years ago. Much of the solder around the tubes on the top and even bottom tanks had cracked and come loose. What I thought was to be a small repair has turned into a major rebuild. Better than dumping the contents on the road I guess. Lucky I have a good old school radiator repair guy nearby. Looking forward to some Spring time Touring soon in both cars.
VowellArt
First Name: Martynn
Last Name: Vowell
Board Member Since: 2012
Post by VowellArt » Thu Aug 31, 2023 7:40 pm
Since it's been too hot to work in the garage on it....I stare at it a lot! :lol:
Fun never quits!
RGould1910
Last Name: Gould
Post by RGould1910 » Fri Sep 01, 2023 12:12 am
I got the 12 roadster on the road finally. Also made a new float for a 5 ball from a block of closed cell material purchased from Langs years ago snd a couple f minor minor things.
Tbird
Last Name: Bird
Post by Tbird » Fri Sep 01, 2023 10:49 pm
Looks great Richard!
