high low bulb socket
grizzledmike
First Name: michael
Last Name: cox
Post by grizzledmike » Wed Aug 23, 2023 2:33 pm
does anyone know where I could get some headlight sockets high low the part where the bulb goes into
Tadpole
First Name: Tad
Last Name: Glahn
* REQUIRED* Type and Year of Model Ts owned: 1925 Coupe, 1926 TT Closed Cab, 2 1924 Runabouts
Re: high low bulb socket
Post by Tadpole » Wed Aug 23, 2023 2:54 pm
Do you mean these? Snyder’s should have them, part#T-6574-X
Bill Robinson
First Name: Bill
Last Name: Robinson
* REQUIRED* Type and Year of Model Ts owned: '21 Depot Hack, '25 Touring Car, '26 Roadster Pickup, '27 Tudor, & another '27 Tudor
Post by Bill Robinson » Wed Aug 23, 2023 4:46 pm
Read this thread from a day or so ago. Lots of discussion about the headlight sockets and any vendors who has any in stock.
https://www.mtfca.com/phpBB3/viewtopic.php?f=2&t=37785
mike catlin
Last Name: Catlin
* REQUIRED* Type and Year of Model Ts owned: 1923 depot hack
Post by mike catlin » Wed Aug 23, 2023 5:22 pm
Maders model t parts had them in Wisconsin
Post by TRDxB2 » Wed Aug 23, 2023 10:17 pm
Are referring to the socket to fit bulbs with offset pins?
The normal setup was weither a BA15S (single contact) or BA15D for (Double Contact). Sockets for bulbs with offset pins are BAY15S or BAY15D.
Since BAY15 style bulbs are normally brighter & perhaps the source of the question. But I am unaware of Model T sockets with off set pins. Most users simple break off the high pin without issue. Other use LED bulbs. Trying to fit a BAY15 socket will require a tab to allow for adjusting the bulb to meet the focal point of the reflector
Arbs
Last Name: A
Board Member Since: 2022
Post by Arbs » Thu Aug 24, 2023 5:23 am
A couple of weeks ago double pin light sockets were out of stock at Langs, Snyders, MACs, and Smith & Jones. Chaffin's had them but they confirmed that they are struggling to order more. You may want to pick them up from Chaffin's while you can. Chaffins: (951) 226-7331
Availability across vendors may have changed since then.
RVA23T
Last Name: C
Post by RVA23T » Thu Aug 24, 2023 8:51 pm
Might try here for sockets and led bulbs
www.ledlight.com/ba15d-socket.aspx
Post by TRDxB2 » Thu Aug 24, 2023 11:21 pm
If you are looking for this, I have several new & used. email or PM me if you need them
