brass tags
Topic author - Posts: 1707
- First Name: Melba
- Last Name: Nolan
- * REQUIRED* Type and Year of Model Ts owned: 23 roadster
brass tags
Can someone tell me what these brass tags are for. They are round and oval with numbers on them. Also on a steering shaft what is the difference between a round top and a triangle top. Couldn.t post picture.
- First Name: Robert
- Last Name: Jablonski
Re: brass tags
Looking at those tags with numbers, would they indicate a date like 321, that could match March of 2021?. Some of us who do rebuild things could put such a tag on a differential housing, steering column starter or generator, or even have numbers impressed into the wood of an ignition coil..... That would indicate when the item was rebuilt or refurbished.
- First Name: Melba
- Last Name: Nolan
Re: brass tags
the oval tags are about 2" wide and about 1" 1/4 high. some have. some of the numbers are: 0 - 2 1/4 - 1/2 -2 1/4 - 1 3/4 -1 - 2 and the round ones are an inch in diameter with the number 2 and 150. the 1.5 inch diameter has 544 and the others are blank
Re: brass tags
Regarding the steering shaft - only round ones I've seen were the reproduction Texas T Parts - Ford had a triangular top.
- First Name: Melba
- Last Name: Nolan
Re: brass tags
thanks for the info on steering.
Re: brass tags
How about some photos?
- First Name: Melba
- Last Name: Nolan
Re: brass tags
couldn't post. can email or text
