ISO 1924 dash switch
Tim D
Topic author - Posts: 212
- Last Name: Dickson
- * REQUIRED* Type and Year of Model Ts owned: 1912 speedster 1911 Torepdo
I have a 24 dash switch that needs to be fixed or exchanged for a good working one. Also need an Amp gauge.
Re: ISO 1924 dash switch
I can repair your switch (have all parts needed original & repro) and have tested amp gauges. If what you have matches the patina of your car its best to have it fixed Will send you an email via the forum
su8pack1
- Last Name: Kelly
- * REQUIRED* Type and Year of Model Ts owned: 1925 Roadster
I have a 1925 roadster dash switch that needs repair. Using a separate on/off switch now.
email sent
To all help out those in need while Ben Martin recuperates. I have repaired many switches but don't do this as a business
If someone repairs your switch - take pictures of it, front & back, post it or send a PM to document it
USPS Insured mail small flat rate box insured (without ammeter) Total postage both ways about $21 using
Lang's backing plate if needed $36
Original tumbler with key if needed $32 (I don't sell these individually)
My labor $10-$20 max (nothing to see what it needs)
su8pack1
- Last Name: Kelly
I just got my switch back from Frank and it now works as it should. Quick turn around time, Thanks.
J1MGOLDEN
- Last Name: Golden
I talked with Ben last night and he is recovering nicely from his eye surgery.
He is rather upset over the number of people that he has restored and returned Ignition Switches for, but somehow they seem to forget to pay him for all the work he does to make them perfect.
