Finned RAJO exhaust manifold question
Popemcman
Last Name: Morris
Post by Popemcman » Tue Sep 12, 2023 2:33 pm
I have a finned RAJO exhaust manifold that is incomplete. The exhaust pipe exits from the bottom of the manifold. The missing part holds the exhaust pipe somehow. Does anyone know what the missing part looks like? Thanks. First time on the forum haven't figured out how to attach photos. Mike
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: Finned RAJO exhaust manifold question
Post by Dan McEachern » Tue Sep 12, 2023 2:46 pm
There is an extension piece that routs the exhaust down from the exhaust manifold and around the water connection casting. They are pretty rare.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Tue Sep 12, 2023 3:27 pm
You can attach a header flange on some proper diameter pipe and it will work fine until you find an original.
22centerdoor
First Name: David
Last Name: Stauffacher
* REQUIRED* Type and Year of Model Ts owned: 1922 Centerdoor
Post by 22centerdoor » Mon Sep 18, 2023 5:11 pm
Actually, any competent muffler shop should be able to manufacture you a suitable header.
jelenbaas
Last Name: Elenbaas
* REQUIRED* Type and Year of Model Ts owned: 1914 Runabout, 1916 Delivery, 1925 Roadster PU, 1926 Speedster
Post by jelenbaas » Tue Sep 19, 2023 10:43 pm
Any idea the purpose of the 2 bolts coming out of the top of the manifold are for?
Post by speedytinc » Wed Sep 20, 2023 8:02 am
Not stock. Maybe for a carb air heat pipe.
